Asteroids Video Issue - Stairs
ataridude74
265CR
I've been fixing up my Asteroids, it was playing blind but slowly it's improving as I replace ICs, now the picture fills the screen but there are issues with the image dissapearing in sections along the X asix, photos below. The test pattern is like a staircase.
I don't want to shotgun the whole video section, so far I've replaced two of the three multiplexers in both the X and Y sections, so there are signals on all lines on the latch outputs going to the DACs (as measured with a logic probe not a scope).
Is it something further back in the chain in the position counter section? Or even further back in the vector generator?
The game plays fine, I can even clear a few boards.
keptboy
73CR
Mine is the same it kind of does not delete or blank
Off the lines afterwards
It is not a Pcb or a power board issue this is a monitor issue
yorkshire_spam
765CR
I'd bet good money it's a PCB fault in the X section.
Rather than shot-gun everything I'd put good high-quality sockets in for the X/Y DACs (B11/B12)/(D11/D12) and the analogue switches (B12/B13)/(D12/13) and then swap them over to see if the fault moves from X to Y
Outside chance it's the op-amps or capacitors.
ataridude74
265CR
Thanks everybody for the feedback, to respond to each suggestion:
The monitor is fine, it works with a Battlezone board and 2 x Asteroids Deluxe no issues. Thanks for the offer anyway.
The top photo is the grid in test mode, the one with the 'staircase'. You can see the brightness gradient in the middle, that displays OK.
All of the TL081s/082s and 4016's have been replaced (before that no picture at all). Swapping the X and Y DACs makes no difference.
Not sure which capacitors you mean?
I'm thinking the issue is further upstream, maybe the LS191 counters? There's only three of them worst case... It's like it can't count properly along the X axis
Equites
Chief Sheesher®
35 (100%)
3,329CR
Where did you source the op-amps from? China is the wrong answer.
Equites
Chief Sheesher®
35 (100%)
3,329CR
ataridude74 said:
No, e-Bay, bought stuff from the seller before, seems legit - http://www.ebay.co.uk/itm/301665999454
Throw them in the bin. The last set I got from ebay were fakes. ST branded?
I bet that's your problem.
Only ever use a proper outlet like Rapid Elecronics, RS or Farnell for these. Equites2021-05-07 17:17:24
ataridude74
265CR
Don't think the op amps are at fault, I swapped the X and Y chips around and made no difference, same as before the Y axis has no issues and asteroids and ships move smoothly, only problems on the X axis. They're TI brand, never had any issue with the seller's products before.
You can't see from the photo but the asteroids and ships pulse (around every second) expanding and corrupting and then shrinking back to their correct shape. Doesn't happen with still objects such as text, and only horizontally, they're stable vertically.
It seems counter-related, nothing obvious as everything is pulsing with the logic probe, no stuck outputs. Could it be a capacitor issue?
big10p
Coins detected in pocket!
6,092CR
I know this is a long shot, but on the Vectrex, there's an op amp IC and the TI branded ones don't work for some reason. Vector alignment is messed up. No idea why but an alternative brand has to be used when replacing it.
