Astro blaster repair
PhilT
154CR
Hi Folks
I go through phases with Astro Blaster cab, its never worked and is frequently one step away from becoming bonfire fodder, so after sourcing some new RAM for the video board I thought I would have another play with it.
Replaced all 16 RAM chips, the original ones pretty much fell apart anyway as I removed them from the sockets so I had to replace half the sockets too. The SRAM had a couple of broken rotten legs so replaced that and its socket too.
Fired up just the video board and for the first time got something on screen - red jail bars -
So red jail bars would tend to point to stuck bits on logic chips somewhere but I am not sure what I should be seeing.
Can anyone with a working Astro Blaster pcb set (if there is such a thing) tell me what they see on screen if only the video board is hooked up in the cage - full red screen? (hoping!)
Phil
ColinD
6 (86%)
1,367CR
There was a guy who knew the Astro Blaster stuff inside out and I bought a machine off him.... I completely forget his name right at this moment, he had his arcade games on the ground floor of his business premises and had a dental lab above. I'm sure someone will know, somewhere around south of Birmingham ??
Equites
Chief Sheesher®
35 (100%)
3,332CR
I think it was Martin, forget his member name but sure it has Martin in there. Yes he was from Brum.
I can help with that question once my new workbench is setup.
4,058CR
I fixed a bunch of these in the past (don't do repairs any more before anyone asks!) and in theory have a working set in the loft but around 1/3rd of what comes out of my loft doesn't work any more and these are picky to begin with. I seem to remember I used the Astro Blaster set to prop up the TV aerial
I can't answer your specific question off the top of my head, but I'm curious to know how you are working on the PCBs?
If you're working on them on the bench then be careful. It is technically possible to run them from Jamma voltage but it will kill the RAM on them. Again, can't remember which RAM it was but there's some RAM that needs -12? or -15? and if run from -5 it will work for a bit then die.
Just saying. When I worked on them someone lent me a specific little inverter to do the job of providing the required voltage.
PhilT
154CR
ohh another board set - interested in selling/loaning it out for a while?
Its become a bit of a grudge match with this thing. I wouldnt buy anything in the same conditions now. Should have skipped it really - dirt + damp = too much corrosion on too many chips but ya never know - maybe one day.
re powering the boards, I have a switcher hooked up to a vector power supply board and into a cage I dismantled so I can power the boards up correctly and access the components.
It is indeed the ram chips (4015 I think) that need 3 different voltages, so I dont have it on a jamma rig.
DanP
Administrator
2,232CR
By far the easiest way to diagnose these board sets is to start with another working set and then use it to isolate which of another sets boards is working/has issues. For your issue, it might be a bad VIC chip (a custom IC), if that's gone then you're buggered. These haven't been (to my knowledge) reproduced, the only source is another G80 raster set. There was a VIC eliminator produced by SEGA but these are even harder to source than VIC chips.
To test Astro Blaster you can remove both sound boards so you've only got the 3 to work with - CPU, Video and ROM. It's also worth swapping them around in the stack to see if the problem changes, they don't have to be in any specific slot. Sometimes you get a bad contact on a connector slot that causes wacky issues. Try cleaning the PCB edge connectors with a pencil rubber. Have you verified your ROM board is OK? Can you read/test each of the eproms to confirm they are OK? As I said, much easier to do that if you have another working set (or know someone nearby who has a working cab), you can just plop the board in and know straight away if it's OK or not.
Good luck!
Dan
