Atari 7800 basic programming
Purity
The Oracle
17 (100%)
2,999CR
Does anyone have any experience of programming in Atari 7800 basic? I'm trying to get my head around it to write some code for testing POKEYs but I'm struggling :-(
Purity
The Oracle
17 (100%)
2,999CR
Sadly that didn't yield much help.
I've found two snippets of code, both look like they are written in C
http://atariage.com/forums/topic/146725-detecting-pokey
http://7800.8bitdev.org/index.php/Detecting_POKEY
This will test the random number part of the Pokey.
So far I've not been able to compile this code in either CC65 (first link) or other C compilers for the second link (DASM etc)
No idea where I am going wrong :-(
My knowledge of C is very limited so I'm a bit stuck
As far as I understand, if I can compile it, I can reference it in the Prickle 7800 BASIC program
Purity2017-04-14 20:30:46
philmurr
46 (100%)
2,326CR
They're 6502 assembly language. Shouldn't be too hard to expand them to test more functionality of the Pokey
https://archive.org/stream/Programming_the_6502/Programming_the_6502_djvu.txt
philmurr
46 (100%)
2,326CR
There are some variables that you need to declare in zero page (pokeybaselo, pokeybasehi and pokeydetected) and (PAUDCTL, PSKCTL, PRANDOM, gamepokeydetected) otherwise the assembler will fail.
Edit: sorry to clarify, paudctl, pskctl & prandom are addresses used to communicate with the pokey, they're defined in the programme at http://7800.8bitdev.org but not in the other
philmurr2017-04-14 21:15:41
