This follows on from a thread jengineer started a few weeks ago about a medium res monitor in a paperboy cab.
He couldn't get the monitor to work but could hear the game play blind etc.
Long story short, two smpsu's had been fitted, supplying the CPU board and video board separately with +5v.
The game was playing blind because the +15v rail to the video board wasn't present, the AR3 was sending 15v to the CPU board but not the video board.
I only know this is the case due to making a bench loom recently for Paperboy and getting caught out with this issue.
Btw, +12v is just not enough, it'll start but weird things happen.
So, i've set about getting the AR3 back in the loop as it should be, i've tidied up the connector to the video board for power, everything nice and snug. I have +15v no problem.
However, i can't get 5v out of the AR3 when loaded.
Unloaded i can get 5v and its adjustable, loaded i get 2.9v and not adjustable.
I've changed Q7/Q8 (the 2n3055's), changed the LM305, tested the TIP32 out of circuit etc, checked every resistor and capacitor and diode.
Originally one of the 2n3055's was getting screaming hot within seconds, i reseated it by removing and resoldering and that stopped, they are getting warm but apparently thats normal but not where a smell was coming out.
I have +15v at its test point and the positive end of C19.
I have 14.6v on the 10.3v line but thats from the brick.
I get 21.6v on the +22v line
I have 14.6 on the collector of Q7/8
I have no control of +5v adjustment when the video board is connected, but have control without.
Someone has attempted a sense mod on J7. Pins 2/3 are linked and 5/8 which looks right but not sure if necessary for an AR3.
I don't have CR8populated - a 1n4002 - is this crucial.
I can change the TIP32 but i don't believe it'll fix it.
The only things i can think of are:
1, the board is overloading the AR3 and causing voltage drop
2, there is a short on the board.
3, the AR3 is still faulty.
Anyone had this issue before?
