So I got a couple of Area 51 boards off ebay a while ago which were "untested" and had no hard drives.
The first thing I did was use CHDMAN to create a couple of replacment HDDs using the MAME romset. There's a really nice, simple guide for this here:
http://www.thekillerinstinctproject.com/kiproject/chdman.html
Once that was out of the way I hooked them up and unsurprisingly, both boards had issues.
The first did nothing on boot. It just kept resetting. I put this to one side for the moment and tried the next which actually did boot, albeit with gfx issues and no sound.
This is where I got a little lucky. This board is mostly made up of surface mount components and as such, can be damaged by just flexing the board. I right away saw the CPU and DSP had some poor connections so I got a little flux on there and reflowed both ICs.
This time it came up perfectly with no issues at all, except, still no sound.
I then checked the sound path and saw it stopped at a small DAC (AK4309AVM) here:
Data going it seemed good but all the outputs were held high. A quick Google search later and I found the Playstation 1 used an almost identical DAC. The model I had on hand was a scph-1002 which used a AK4310AVM which looking at the datasheet would work just fine in place of our faulty DAC.
You can see here on the PS1 where I removed the DAC IC:
Fired it up and all worked perfectly.
Going back to board number 1 I checked the CPU again right away and low and behold, it looked quite rough. Reflowing this got it working perfectly. I'm not sure if this was a fluke or if quite a few of these boards have poorly soldered CPU/DSP ICs but it's certainly worth checking first if you have a similar issue.
retrorepair2012-05-29 10:01:17
