Atari ARII measurements
petercasino
212CR
I'm just hooking up an ARII that I haven't used before and I'm checking the unloaded voltages at the test points before I hook it up to my PCB. I'm getting the following readings:
+10.3VDC UNR = 14.5V
+5VDC = 4.9V
+12VDC = 11.8V
+22VDC = 24.1V
-22VDC = -24.2V
36VAC = 36.4V
-5VDC = -14.9V *******
The odd one out is the -5VDC which measures as -14V! I'm guessing that means there's a problem with my AR2 board? Any ideas what the problem might be?
Thanks,
Mike
petercasino
212CR
Thanks, the pcb boots up fine
Battlezone
410CR
That's very useful to know. I tested a handful of AR-II boards the other
day (unloaded, but with sense connections in place) and they all
read about -5V. I think I'd have started looking for problems if
they had read -14V. In future I can load that supply before worrying
about suspicious readings.
Battlezone
410CR
I might try replacing the 7905. As I said all the boards
I tested measured very close to -5V even when unloaded.
[I might also take back what I said about loading my boards
before worrying about that supply in future.
It may work now but you probably don't want to overload
the -5V chips by 7V for very long.
Battlezone
410CR
I could only find a largely unreadable Warlords schematic but
I can confirm (as Nad has done) -5V is used. At least it's
used in the output audio amplifier (maybe other places too).
Interestingly in the audio circuit it goes to an op-amp with
+12V on the other side so maybe for that one gate -12V is ok.
tb lilley
5 Star
1,686CR
Just to add - the last 2 ARs I checked gave approx -14VDC on an unloaded -5 line. I have read somewhere that some 7905 will read fine without load. First AR I checked that read -14VDC I replaced the 7905 - still read -14VDC without load, bang on -5 under load.tb lilley2016-04-06 13:31:49
petercasino
212CR
Just measured the voltage at the test points on the pcb and it's -12V there too. The game is running though and I can hear sounds. I'm just connecting the monitor up at the moment. I've not connected the pots yet, I don't suppose they will have any effect?
petercasino
212CR
I've finished wiring everything up and the game appears to fully work. The -5V still measures -12V though, do I need to look into that issue further?
Mike
