ATARI Battlezone
leslie
42CR
Hi all i hope you dont consider this as a stupid question,but i have a b/z up right and the radar and score and enemy range are not in there correct position(too low on the monitor) do any of you guys know how i can adjust this (raise it about 3") not shore if it just needs raising or maybe the pictures too small? any thoughts ?
4,058CR
Look at the game PCB, near the edge connector. I forget which exact ones you will find there but you should find adjustment pots for X Size, X Position, Y Size, Y Position. There are also some adjustments called "BIP" adjustments. Don't adjust these!
You should be able to read what the adjustments are. Don't just randomly adjust.
If you can't get the picture where you need it with them then you may need to adjust in the monitor, but try the PCB first.
