Atari Cabaret ARII Light Mod
aeroflott
A different league
16 (100%)
1,060CR
This might help someone out. My Centipede cabaret came without a marquee light from the factory - it appears this is a common thing. Atari put the light housing in some cabs (like my Tempest cabaret) but not others.
It's been bugging me for a while, so decided to do something about it this week.
Decided to use the 12vDC from the ARII to power the light, as this would require minimal hacks to implement.
So bought one of these http://www.amazon.co.uk/Biard-LED-Caravan-Motorhome-Voltage/dp/B00BEOKFN8. It's a simple LED strip light with brackets for 12 quid.
Put together a small length of wood and fitted it so I could mount the LED strip behind the marquee. It's about 20cm behind, and secured to both sides of the inside of the cab:
To get power from the AR2, you need to hack into the P10 block. Pin 4 is 12v and Pin 12 is GND. I removed those pins, and dropped the relevant + and - wires into the back of the pins and taped the wires secure:
Then popped the pins back into the block:
Secured the LED strip into the mini brackets, switched on and voila:
Here's the view looking up through the coin door:
And all lit up:
Took about an hour all told, without having to hack the loom.
TT
4,058CR
Stevros said:
Nice hack, now i know how to mod my k6100 hv cage with a fan
Be wary of hanging a fan off the 12v line. I'm not saying that it will, but if you do it and you find you have additional noise out the speakers afterwards then don't be surprised. Modern fans may not cause the issue though so you may be OK.
Mitchell Gant
888CR
Also remember that the 12V comes from a 7812 regulator on the AR2 rated at 1 amp maximum, so you're stressing that more by hanging other loads off it, causing more heat to be dissipated in the AR2 heatsink.
I'm sure a small LED strip is fine, but larger LED strips and fans could easily cause trouble or damage.
RGP
Meeter & Greeter
2,039CR
Looks great Tony.
I'll add to Gudd's advice here out of our experience on borrowing from +12v rails.. The AR2 is probably powerful enough to do its regular job and that strip but some PSU aren't so anyone thinking this is a good way to get +12v just take care that the PSU has enough current overhead to cope with both, sometimes the +12v is used for the reset line on some boards and when the PSU has been on for a while and got warm the extra load might be enough to drop the voltage enough to reboot the game.
This definitely happened when we wanted to fit one of these strips to Star Wars Trilogy - it was fine for a few hours then under gameplay started to reset. Remove the LED strip and its fine.
For a lot of games it'll probably be just fine but something we've experienced.
RGP2014-10-22 18:36:40
2,265CR
Nice work, it's weird how they didn't bother fitting lights to so many cabarets, and looks so much better with it done.
aeroflott
A different league
16 (100%)
1,060CR
Thanks chaps, some interesting observations there. As it happens, my youngest son left all my cabs on overnight last night (it was pretty warm up there this morning I can tell you), and everything, including the Centipede with it's LED mod, appeared to have survived without burning the house down.
As its been pointed out, whilst the additional load I think is unlikely to cause problems, it has been suggested that tapping into the unregulated 10.3 VDC pin at P6 on the ARII instead, so as not to risk any problems, might be a sound alternative.
Obviously this is a 5 minute tweak that I can easily do - and report back. Any reason not to? I'm not knowledgeable about unregulated vs regulated - and bear in mind this is a 12v LED strip.
Any thoughts?
obcd
3,830CR
Usually, in such a strip, there are a number of led's in serie. This prevents the additional serie resistor from consuming to much power. Depending upon the number of led's they put in serie, it might still work on 10.3V, or it won't give any (or very little) light anymore. You can't damage anything by trying it out. If it works, it's indeed a safer solution.
