Atari CAT BOX
Mike Mnemonic
9CR
Happy new year to all.
I have recently acquired an Atari CAT BOX. I do not know its history so it could be either for 110V or 230V. There are no internal voltage select jumpers that I can see so it looks like a different transformer is used between the different models.
I wonder if there are any other owners with a CAT BOX, if they could measure the resistance of the Live to Neutral on their unit so that I can compare it with mine. A measurement of either the 110V or 230V unit would be equally useful. Also, what fuse is fitted?
Mike
DanP
Administrator
2,232CR
The CAT Box runs on 110v only you'll need to use a step down transformer. The manual actually lists a step down under the parts list for European CAT Boxes
http://arcarc.xmission.com/Test%20Equipment/Atari%20Catbox%20&%20Pods/Catbox_TM-179_1st_Printing.pdf
I can take any measurements if you still need them. Mine has the hidden checksum modification on it which adds another useful feature.
http://arcarc.xmission.com/Test%20Equipment/Atari%20Catbox%20&%20Pods/Catbox_Mod.pdf
HTH
Dan
pobtastic
477CR
Northants is now home to at least TWO ATARI CAT BOXES!!!
@mike Mine is fully working (when stored), so if you want to take any measurements yourself ~ I am fairly local.
Kingpin
113CR
I can confirm that it is 110V like mentioned before in the thread.
It's quite useful when diagnosing classic Atari titles in the field.
I would like to take the opportunity and ask if someone want's to trade a Z80 interface for a 6809? If so let me know.
Kingpin
113CR
Hmm, maybe that did come out the wrong way?
I'm looking for a 6809 interface and have a Z80 interface to trade with.
Kingpin2020-02-06 15:16:27
DanP
Administrator
2,232CR
Heh yeah I read it that way. I've been looking for a 6809 pod for the last 10 years or more, never ever seen one. They look simple enough to repro if one could ever be found to base it on...
Kingpin
113CR
Yeah, a repro should'nt be that hard to do as long you have a original to start from. The Z80 interface is quite simple at least (when compared to a much more complicated Fluke pod for example).
I have 2 x Z80 and 1 x Z8002 interfaces.
