Atari Centipede display 5 error query
Mark H
98CR
Hi All,
I was playing my Centipede and the sound went off and then all the mushrooms displayed on the screen were nearly all in a vertical line on the far left and right of the screen with none across the rest of the playfield however the trackball controller did still work. I then did a "self test" and the number 5 was displayed in the top left corner of the screen. Ithen tested all the buttons on the self test screen and then switched back into the game and it played fine.
Any ideas please and the manaul states a 5 is a "failing ROM/PROM" at locations B/C/D3 ? Is that chip easy to loacte on the PCB?
Mark
5,414CR
Anything in the Atari Manuals, there quite good and do have some errors and tell you chip locations etc
I find them about the best manuals of all arcade machines
5,414CR
Mark H said:
Hi All,
Mark
Would help if I read it all wouldn't it
Don't it show you were it is? but I assume that mean line 3 and chip/chips in B C D
so like this if it was this way round, or A B C down side and 1 2 3 4 5 etc across
pcb say under
1
2
3 B C D
4
5
6
depending how big the IC is if it spans all 3,
Mark H
98CR
Thanks - I will check the PCB later. I'm still not sure how it resolved itself though and the number "5" is no longer displayed on the self test screen and it seems to play ok now.
Mark
5,414CR
That's unusual, unless the chips are socketed but good also
I would leave it while working ok and if same happens and they have sockets look at cleaning the IC legs or replacing sockets
That's why I like the Atari manuals though, they really help, also tips on removing old IC's when faulty, respect to the USA for that
It didn't make much sense to me at first the chip locations on pcb's until I started looking at exist crossbow boards, I was checking the EPROMs which turned up some interesting stuff, as only 4 or 5 were coming back as good out of 30+ that's when you start understanding how there named in mame as part of it is the chip locationBods2017-07-07 16:28:20
Mark H
98CR
Hi thanks. I played it again in the week and it was OK. I only usually leave it switched on for around 90 minutes at a time. The day the fault happened was when I left it on for around 8 hours and then came back into the room to play it and it had the fault with nearly all the mushrooms in a full vertical line on both sides of the screen with no sound so I'm not sure if something had over heated?
Mark
Mark H
98CR
Hi All,
Now resolved via James Brindle at Retro Games Party:
Found bad POKEY chip causing ROM 5 error in test mode as presented. Replaced and
working.
Mark
