Atari connector crimp
strykr
1,351CR
Hi all, does anyone know what crimp tool I need to repin these?
obcd
3,830CR
At work, we have a special AMP tool for those. You insert the connector and insert one wire. It's pushed upon the pin and the isolation is cut so that the pin makes contact with the wire. The connector moves up one position so that the next pin can be wired. The pin's are not separated from the housing. We have 2 sizes of those connectors which require 2 different heads for our AMP crimp tool.
If you onle have a couple of wires to reconnect to one of those, you could solder them to the pin's. It's not a proper view, but it gives a reliable connection. If the connectors are used a second time, the opening can be larger from the previous inserted wire and the connection can become unreliable.
bonehead
I'll get pix tonight
50 (100%)
1,729CR
You could cheat and use a flat screwdriver to push the cables in.
I got my correct tool from pinball mania as I use it for fitting
Connectors on my pinball machines.
strykr
1,351CR
I tried that Steve, and have applied that method in the past with smaller opto pcbs etc, these wires are power lines though and a much thicker gauge. By the time i'd forced it in, the wiring was pretty mangled.
Im gonna try again tomorrow with a punch down tool, toolstation has one for 8 quid which is worth a crack i think.
I will consider soldering direct to the pins, but so far everything about this champ sprint has been about keeping parts and wiring 100 percent original and although its been a massive expensive grind im gonna persist!
strykr2015-01-17 21:06:03
strykr
1,351CR
Steve said:
It's worth taking the time to get it right.
How is it going? Any further developments?
Only bad ones
F3 fuse blew and puff of smoke. confusing as it wasnt under load, ive not even begun the wiring into the AR3.
New fuse holder bought, new fuses on there way, gave the power brick a good once over today and all seems ok, bridge rectifier checked out etc, once the new stuff arrives i will try again and troubleshoot.
RGP
Meeter & Greeter
2,039CR
I hate IDC terminals with a passion - every game i've had to work on (usually Paperboy / Williams games) have these and become a point of failure over time as the loom hangs on them and with age they give as they only bite the wire.
They are fine if you support the loom all the way down the side of the door.
You could always use the proper crimpable 0.156" headers and pins.
Notice how on a System 2 board that the upper connector on the CPU board is that type but generally I've found the lower video board to have a pin insertion type.
There are two types used on system 2 boards - 0.156" for the power connectors and 0.1" for video and other harness plugs.
I have worked through a few cabs and replaced the connectors.
If you want to go that way you'll need:
THIS crimp tool (HT-225D).
THIS connector (09-50-3101 10 way 0.156" KK series)
THIS crimp terminal (08-50-0071 0.156" 18-24awg)
Note you actually need a 09-50-3091 (9 pin) for the CPU board but you can just cut one position off with snips and a stanley knife. The 11-pin for the video PCB is 09-50-3111.
The issue is I can never find these two so I get the 10 and 12 ones and trim as needed.
The entire range is still listed in the Molex catalogue as in production even up as far as 20pin but I can't seem to find stocks in the UK.
Let me know if you want to re-pin the 0.1" ones too as i'll have to find you the part codes for the headers and the right pins for you.
They are all in the 10-11-2XXX series
