I've been busy..... My Roadblasters 'cocktail' board in the Cockpit has died and needs a new GPC chip.....
I've robbed one from the Gauntlet to repair... so I can test the Slags Modules on it.... alas... not fully working yet on this , but the Slags at least work on Gauntlet....
There are still a couple of problems with the Roadblasters board, H Scroll is not right and no cars... !!
anyway..... thought I'd try to put a GPC chip together in VHDL..... It's took me a couple of days and needed some help with the final high z output on 8 of the outputs..... but it seems to compile ok now....
the design uses a prom for decoding, so I dumped the prom from my system 1 logic board and that's all sweet and included
However..... I need a CPLD / FPGA module with 40 pins..... might see if I can get one from a couple of sources, or I will have to design my own..... !! ( it has odd power pins like the slags)
The only issue I have with this is that in the original circuit there is a /HO3 line.... and this does not go to the GPC chip, so I may have to modify a little or do some testing to regenerate this based around the H4 signal...
ColinD2016-05-21 19:40:38
