Atari GPC Chip - It's WORKING !!
ColinD
6 (86%)
1,367CR
Worked back and found the actual main issue to be an unused pin that on the CPLD that was sharing one of the AlphaNumeric APIX1 Inputs.... I had to route the track to another pin as the design would not fit but left it going to the old pin too as the pcb routing was getting nasty !!
This pin was set as an output and should have been set as an input. So the APIX1 input line was fighting an output pin while trying to drive an input pin at the same time ! - Basically a short circuit !!
Cheers, Col
ColinD2016-05-21 20:24:38
ColinD
6 (86%)
1,367CR
Another major issue was regenerating the /Ho3 line internally on the Chip as its not connected to the Custom IC but is used internally (and on the schematics).... I had to design some logic to remake the missing H signals and used other available signals to synchronize up. This was the hardest part of the project !!
