Atari Power Brick confusion
Purity
The Oracle
17 (100%)
2,999CR
Hi chaps,
I was wondering if someone would clear up a confusion by looking at some Atari Paperboy schematics found here:
http://arcarc.xmission.com/PDF_Arcade_Atari_Kee/Paperboy/Paperboy_SP-275_1st_Printing.pdf
I've been measuring the brick voltages as per sheet 2B "Video Display Wiring Diagram", and the voltages check out on the 15 pin connector (J5) and the 3 pin connectors (J4A and J4B). I have bypassed the interlock at (J2)
So far so good in the sense that the brick checks out with the voltages listed 10.6vDC, 36vAC, 6.1vAC, 60vAC and 120vAC as seen here:
What's confused me is the information on sheet 1B "Main Wiring Diagram". It has two 3 pin connectors called P4A, and P4B, a 6 pin connector called P2 and a 15 pin connector called P5
I thought these were the same as the J connectors however whats got me confused is that it suggests that on the 15 pin connector I should have 120vAC on pins 15 and 10 that got to the medium res monitor, however the voltages on 2B make no reference to this. Can anyone explain please? I can only see 120v AC on the J4A and J4B connectors
Cheers!
Purity2017-11-26 20:07:07
tb lilley
5 Star
1,686CR
I think its because one set of voltages is centre tapped (60 VAC CT) and the other is vanilla VAC (120). So they are both 'correct' but are showing different things.
Purity
The Oracle
17 (100%)
2,999CR
So I should be getting 120v AC on pins 15 and 10 of J5, because sadly I don't? Everything else is spot on, looking at the J5 connector schematics
Purity2017-11-27 08:54:14
bomjac
453CR
Check 10-12 and 13-15. Should be 60v ac on each of them. 10-11, 11-12, 13-14, 14-15 should all have 30v on them. Also because 12-13 is shown as connected, that should read 0v.
Verify that the link 12-13 is installed also. The 120v is derived from the 2 60v center tapped windings connected in series. bomjac2017-11-27 10:06:55
