Atari power brick missing mains selector plug
big10p
Coins detected in pocket!
6,093CR
This is the power brick from my US Asteroids Deluxe. It doesn't have the mains selector plug, so needs to run from a step down transformer.
As the cab's US power lead is going to need replacing/fixing due to damage, I wonder if it's possible to wire something up in the power brick, so that I can run it on UK mains power? Not sure why the usual voltage selector is absent. Does this mean the transformer doesn't have the windings to handle UK mains, so I have no choice except to use a step down?
Cheers!
aeroflott
A different league
16 (100%)
1,069CR
Assuming the power brick actually works (it looks like its missing some fuses from that pic), it just needs the correct mains selector plug, although it looks like the block that it would connect to has been removed?
I have some spares somewhere which I could dig out if you're looking for one (You might need to reroute the wires as I'm not sure which region they are for). Drop me a PM if you like.
Or get someone to share a pic of theirs (I'm not sure if they are common across all power bricks for all games) and you can build your own.
Edit: this thread has some good info: https://www.ukvac.com/forum/threads/atari-brick-voltage-selector-plug.82690/
big10p
6,093CR
Thanks for the reply and offer. Fuses are missing as I took the pic as I was stripping it down to clean and replace the original Big Blue.
It looks like this power brick might have left the factory without the voltage selector, as it doesn't have the plug socket, just the hole for it. Here's the underside.
This makes me wonder if the transformer I have isn't even capable of handling UK mains voltage?
qjuk
51 (98%)
2,136CR
US uprights of Asteroids Deluxe (and I believe the US uprights of Battlezone as well) had unique US power bricks without any voltage selection fitted at the factory.
Either find a European Atari brick or use a 230v to 115v step-down with your US one. My Asteroids Deluxe is also a US machine without the voltage selection, I’m using a 300w step-down fitted inside the machine and it works great.
big10p
6,093CR
Thanks. Did you secure your step-down inside the cab at all, or just have it sitting loose inside?
qjuk
51 (98%)
2,136CR
I managed to find a slimline step down unit on eBay with securing lugs which meant I could screw it down. It’s situated to the left side of the cash box (looking in from the rear).
I also had to rewire the mains lead as well. Just like almost every cabinet I’ve had, the mains lead is almost always damaged in some way :)
