Atari Power Brick with Voltage Select plugs
Wahoobies
498CR
I've got a battlezone cabaret inbound from the states. The manual shows line voltage selection on the Power supply, and the one coming has the origina voltage selection plugs still present.
Anyone have any good or bad luck using these/stories to share? I've ordered a spare power cord to hook up to a UK plug.. I've been wondering if
a) any worries with marquee light/flourescent being different hz
b) will results be reliable using input of 220 or should I be planning to use a step-down
Curious for what experience has taught anyone else!
Here's the bit from the manual about it + arrows pointing to the line selection plugs on the diagram..
1bradders
163CR
I've got an Irish built cabaret but parts are the same. Just make sure you use the brown voltage jumper once you fit the uk plug 👍
Ballast should be fine. I built a light fixture for my centi cabaret using 50hz ballast and runs fine on 60hz uk input voltage. Supposedly they run hotter but I've had no issues.
qjuk
51 (98%)
2,146CR
That’s the nice thing with these Atari bricks, they were built with international markets in mind and it’s a simple case of changing the voltage selection plug to suit your mains voltage.
As mentioned above, the brown wired plug is the correct configuration to run off the UK‘s 230v.
patloz
844CR
Lots dont come with the brown plug but its easy enough to "repin" the yellow one fitted.
I put a 12v LED strip light for the marquee instead of the old tube ( I leave it all in place though ) and use crocodile clips to attach it to the 10v unregulated connector on the AR so i doesnt touch the original wiring and can be removed without trace if needed.
There are some alleged examples of where the US ballast has over heated in the UK but I also prefer to protect the marquee from the heat of the tube as well as this potential risk ( that said I never leave my machines on for long enough where its a problem )
Also no reason to change the power cord uness its damaged, remove the US plug and put on a UK one, the colours are just different
Black positive, white neutral green ground if i remember correctly.
Wahoobies
498CR
Thanks all, that's really cool. Those Clever Atari Designers :) Yes I'm told all the original selection plugs are present in this one, so brown it is !
I figured I'd keep the original power cord untouched inside the cab. The replacements were pretty easy/cheap to find with a couple other spares/fuses etc I ordered at the same time.
a 12v LED strip sounds like a good idea to me too- I could probably find a diffuser/translucent tube of about the same diameter as the Flourescent to hold them in the right spot too. This is just going to be home use so shouldn't get more than an hour of power on at a time.
patloz
844CR
You will need to get the right three pin specific connection on the PSU if you change the cable.
I have the metal squares and cable clamps somewhere which stops the cable being pulled out of the cabinet , they were repro”d by takeman in the US a while ago and I bought a few, you will most likely need both if you change the cable as it’s difficult to get the old one out without damaging it
Hence why I would keep the original cable
Wahoobies
498CR
I've got one of these from arcadeshop on my asteroids, that was the plan for Battlezone too. I can see what you mean about the clamp now I look at photos.
Hmm.. my Sega NAC has a japanese plug/internal stepdown and I use an adapter, I could also do that. I don't know exactly why, but I'm loathe to cut the US end off the original to rewire a UK plug. I was figuring I'd keep US quarter mechs too, bringing me up to 3 separate coins required for 3 machines
patloz
844CR
Stupid question perhaps ?
You are buying a new cable from arcadeshop which will cost you £30 odd quid just to cut the plug off it instead of cutting the plug off the one already fitted with a clamp?
If you are precious about the original cable why not just get a US to UK adaptor and away you go as the voltage will be sorted ?
Maybe I’m missing something ?
Personally I only leave US plugs on 110v stuff and 3 pin everything else , stops me plugging in to the mains by accident
Wahoobies
498CR
Ah much more likely I'm just being stupid. I tend to over-buy spares and parts ahead of the thing arriving.
I think I'll be best off just using an adaptor for it as you suggest.
