Atari -Return Of The Jedi. PCB Repair.
smarty
Ready Player One
1,290CR
Atari Return Of The Jedi. PCB Repair.
I recently acquired an Atari ROTJ PCB in an untested/unknown state. First up I had to make an adapter so it could be wired into my JAMMA test rig.
Upon 1st power up the game loaded and played but had some colour issues with the display and also all the foreground sprites had horizontal line missing from the graphics.
The first photo below show the speeder bike having horizontal lines missing from the graphic, the colours of the trees and the ground also didn't look quite right and seemed to be missing the colour brown
All text and other graphics seemed to display correctly.
The screen below also showed some colour error (Green hue over complete screen) along with missing lines in the Deathstar graphics.
After spending a fair amount of time using my logic probe to find a faulty IC I didn't really make any headway into the issue. I then decided to put the game into test mode to see if the diagnostics would point me in the direction of the fault. Well the game wouldn't go into test mode and seemed to stick on a Magenta/Pink colour screen when switched into test mode. Not a great help I thought... I decided to read the Manual for the game and sure enough a Magenta screen when set to test mode indicated a fault in the Colour RAM section of circuitry. As it turned out a RAM at location 12R was faulty. Initially I piggyback a new RAM on top of this one and the colours came back but it still wouldn't flip into test mode. So I swapped the IC anyway and on power up the colours now looked good and the board went into test mode.
No green Hue on the screen below now, but the missing line now quite visible.
The Atari schematics for this game are nicely laid out, I deduced that the fault was in the Motion Object Horizontal Line buffer areas of the circuit. Again more probing around and Its was not clear what was wrong, I don't like shot gunning parts on a large scale, I like to know what is causing the faults, so I took a break from the logic probe and went for a visual inspection of the solder side of the board and then I noticed something....
Pins on a 74LS163 in the Horizontal line buffer section had been bent over and looked like they were tightly presses into a track from another pin. I used my multimeter in continuity mode and confirmed that some pine were shorted together. I uses a scalpel to lift the pins away from the track which they seemed to have been squashed into. Upon powering up the sprite issue had gone and the game was fully working.
The pins that were shorting were pins 1 (Reset/Clear), 2 (Clock), 3 (Input A) & 4 (Input B).
Note to self to save time in the future, begin board repairs with a good visual inspection especially if the board has been stored for years with an unknown history, anyway the board is work and I'm well chuffed.
Fully working Game images below.
smarty2015-01-02 22:53:40
DanP
Administrator
2,173CR
Nice fix and writeup. The amount of times I've forgot to use the trusty Mark I eyeball tool before anything else only to find the fix with it later. Saying that these days the tool tends to need the "Reading Glasses" add on...
Dan
smarty
Ready Player One
1,290CR
Cheers guys, yes the eyeball's will definitely be taking a higher priority in future repairs!
Any way I forgot to show an image of the offending pins which caused the sprite issue. It was in device location 5N the board. See image below, I think something has scraped over this IC in the past or been squashed up against something whilst in storage.
iamjimmi
481CR
No worries.
But you might be able to help - I have a working board that is missing little square 'daughter' board. Do you know if these daughter boards can be sourced from anywhere? iamjimmi2015-01-03 14:30:46
Equites
Chief Sheesher®
35 (100%)
3,311CR
smarty
Ready Player One
1,290CR
Or are we talking about the 'Pixie' board. 100mm ish square board towards the middle of the board. I think it handles all the background graphics?
Not sure if it's used in any other games, You game should run with a green background without it, but all sprites and game text should still be visible. I was running mine without it yesterday when testing.
smarty2015-01-03 14:46:30
iamjimmi
481CR
Equites said:
iamjimmi said:
No worries.
But you might be able to help - I have a working board that is missing little square 'daughter' card. Do you know if these daughter cards can be sourced from anywhere?
That's your Quad Pokey;
http://www.arcadefixit.com/searchquick-submit.sc;jsessionid=DC613C30771FB86C6DC15C2F9ABCC547.m1plqscsfapp03?keywords=pokey
They have 15% off at the moment till 7th Jan.  Enter the code 20discount15 at checkout.
I am not sure that is the one. I have attached a pic with the missing board highlighted (obviously the board isn't missing on this photo!)
Also of note - there is a seller who has a couple Jedi empty cabs on Ebay at the moment
http://www.ebay.co.uk/itm/Sensible-Offers-Invited-For-Job-Lot-Of-Arcade-Machine-Carcasses-/331410728976?pt=UK_Video_Games_Coin_Operated_MJ&hash=item4d299e6810
Might be of interest to you if he was realistic about their value (and was prepared to split up the job lot)
smarty
Ready Player One
1,290CR
I tried that seller and offered him £150 for both empty Jedi's and he wasn't interested and didn't even counter my offer saying £150 for one of them! They'll end up rotting or being skipped I expect.
iamjimmi
481CR
I think £150 for the pair is a very fair price. Same guy is looking for £750 for two untested monitors! Maybe he just likes storing stuff...
Back to my original question - from the photo, do you think that board is the 'Pixie' board? If I can identify it, I can start to look out for one (or post a WTB).
Thanks...
iamjimmi2015-01-03 15:05:31
smarty
Ready Player One
1,290CR
In the Atari manual its called: PIXI II PCB part number A04268601
It's probably a good candidate for a custom FPGA type device like ColinD did with the SLAG device, it has some 74 series logic a couple of Proms and some RAM.
iamjimmi
481CR
smarty said:
In the Atari manual its called: PIXI II PCB part number A04268601?
Thanks - I will put out a WTB and hope that there is one lurking out there somewhere!
DanP
Administrator
2,173CR
Pretty sure these are only used on ROTJ. Pretty hard to come by, someone needs to have scrapped (or lost) a mainboard to have one spare. As you know they are pretty useless without the other board.
Dan
iamjimmi
481CR
Dan
Thanks - can but try....
