Atari Slapstick Q's
strykr
1,351CR
Are there any Atari Slapstick experts on here? Ideally I'd like to be able to swap out System 2 boards but use the same video board, is this at all possible?
940CR
I am assuming you are talking Paperboy / Championship sprint here. They use different slapsticks, so you would need that chip for sure
Some info here on it:
http://aarongiles.com/slapstic.html
I think there quite a few answer to this question on Klov too from memory, so might be worth a looksee there too.
strykr
1,351CR
Hi Ben, Yeah I have a Super Sprint board i would like to get going in the cab too.
Ive read up that website, just wondered if there had been any advances in cracking it since 2003, or getting new ones burnt that work etc, that side of the hobby is all welsh to me tbh.
strykr2015-01-26 16:56:22
mathj
499CR
Code:
diolch yn fawr iawn
strykr
1,351CR
Code:
diolch yn fawr iawn
Tis true, I understand that as much as I understand this:
On power-up, the slapstic starts by pointing to bank 0 or bank 3.
After that, certain sequences of addresses will trigger a bankswitch.
Each sequence begins with an access to location $0000, followed by one
or more special addresses.
Each slapstic has a 'simple' mode of bankswitching, consisting of an
access to $0000 followed by an access to one of four bank addresses.
Other accesses are allowed in between these two accesses without
affecting the outcome.
Additionally, each slapstic has a trickier variant of the
bankswitching, which requires an access to $0000, followed by accesses
to two specific addresses, followed by one of four alternate bank
addresses. All three accesses following the $0000 must occur in
sequence with no interruptions, or else the sequence is invalidated.
Finally, each slapstic has a mechanism for modifying the value of the
current bank. Earlier chips (101-110) allowed you to twiddle the
specific bits of the bank number, clearing or setting bits 0 and 1
independently. Later chips (111-118) provided a mechanism of adding
1, 2, or 3 to the number of the current bank.
ColinD
6 (86%)
1,367CR
I think its a very niche market (at the moment) and requires a lot of know how and stuff (time and investment vs reward) .... If there was some money to be made, I think the guys like Mark Spaeth,Adam C, Clay or Jrok would be onto it already.
Looking at it, I think the best way would be to decrypt and modify the software and have a generic upgrade one fits all chip to provide the extra memory decoding lines.
Its been said that a lot of the slapstick security locking down was done very last minute in a hurry once they got to the main code release and so the security and implementation in the software is supposed to be pretty basic.
At the end of the Day, the Slapstick basically acts as a memory expansion / rom banking device, so with a simple implementation, I think it would be not unreasonable to just replace the code (which might be a quite a few lines) in the program roms where they access the slapstick to use this simpler version (which would use the same amount of code or less) . I guess this is how they developed the software it in the first place you know ;-)
Cheers, Col
ColinD2015-01-26 20:23:47
strykr
1,351CR
Thanks Colin, So it looks like I need to try and find the individual video boards for each system 2 game then, hmm. I have seen instance where people are running a champ sprint with a paperboy video board etc, would that have been a case of someone at some stage swapping out the slapsticks then?
strykr2015-01-26 20:49:11
