Atari star wars Amplifone issue
mickyc22
67CR
Im after some advice please, I have an Atari star wars upright
with and amplifone monitor. In general
the monitor works fine for a short period of time, then after around 5 mins it
powers down, allowing it to cool off it works again for a few mins. Curious if there are any suggestions, at
present I’ve not looked at the boards, i'm by no means a standard CRT guru, but
this is my first experience with a vector monitor.
I’m aware the chassis is split into a deflection board and
high voltage board
Im sure I get the usual reply's check for dry joints &
recap but was hoping for something more specific, but also realise this could
probably be anything.
Many thanks
Michael
yorkshire_spam
765CR
What do you mean "powers down" ?
Have you tried measuring anything when it does this? Voltages on either the deflection/driver PCB or the HV PCB?
I'd start by checking the input voltages on the deflection/driver PCB (just to rule those out 100%) then the rectified voltages on that board, then the input voltages on the HV PCB, then the voltage reg outputs on the HV.
Then B+ and HV (if you have a HV probe)
Edit: An utterly wild guess stabbing in the dark based on no evidence at all would be Q3/BU406D on the HV board.
yorkshire_spam2021-05-19 18:44:35
yorkshire_spam
765CR
When it "fades out" can you still hear the deflection chatter? Is the spot killer on?
It sounds like the HV is shutting down to me - maybe the EHT overvolt is kicking in?
mickyc22
67CR
There is no deflection chatter, i didn't notice if the spot killer is on or not, im not back at the machine till tomorrow now, just so im clear is the led on the deflection board and indication of if the spot killer is on.
I shall also take some readings, i know i've started this post off with very little info, i was just hoping someone may have seen something similar and saved some deep diagnostics.
Thanks for all the replies so far
yorkshire_spam
765CR
Yeah, LED on on the driver/deflection PCB indicates spot killer is on.
If the HV is shut down IIRC you should still get deflection chatter unless spot killer is kicking in.
mickyc22
67CR
So took some time for it to die on me tonight forv1st time but after about 20 mins image went there still is chattering no spot killer led is on.
Left it off for few mins powers back up fine for a time.
I've given the deflection board a scan over couple dodgy joints reflowed still the same.
yorkshire_spam
765CR
So...
Most likely (IMHO) a HV over-volt shutdown because something got hot and went out of spec.
As per my previous post, Q3/BU406D on the HV board would be my starting point.
