Atari star wars power supply help
Stevros
506CR
Just tested the power supply
Does this mean its knackered and i need to throw it?
Here are my readings, only light and fan connected
so will be a little higher:
Power Brick DC
Red
Black
Expected
Actual
1
4
10.5v
15.45
2
4
10.5v
15.45
3
4
10.5v
15.45
Power Brick AC
Red
Black
Expected
Actual
6
7
37.5v
19.24
8
9
6v
6.68
10
13
50v
51.91
11
13
25v
25.92
I have a problem on pins 6 and 7
Does this mean i need to throw it or can it be repaired?
smarty
Ready Player One
1,305CR
Hi there,
The DC measurements that are sitting at 15V are most likely fine, they are unregulated from the AC, The ARII's will do the regulation to the required to give precise levels.
The AC measurement across pins 6 & 7: These two pins come from transformer via fuses F4 & F5. Take the measurement from the transformer side at the fuse block to see what you get coming out of the transformer. Red lead to F4 fuse holder and Black lead to F5 fuse holder transformer side, The cable colours should be RED & RED/WHITE. If that gives the correct reading do the same but after the fuse, then again at the connector block. You should be able to see if it is cable/connector/fuse holder/ transformer related.
smarty2014-09-08 10:26:10
Stevros
506CR
i put the black on pin 7 and the red direct to F4 and i get 38.65 volts
i put the black to pin 7 and the red to pin 6 and i get 19.30 volts
Half asleep after refitting monitor and removing pcbs so will take another look tomorrow, thanks for your help
tb lilley
5 Star
1,686CR
Odd .....
Check for continuity between fuse F4 and pin 6. I'm thinking that pin 6 isn't connected to F4 (ibut t should be, according to the schem).
Is the 36V centre tapped? I note that one of the readings is pretty much exactly half of the other reading. So maybe pin 6 is the centre tap.
Anyway - if you don't find continuity between pin 6 and F4, try to find continuity between F4 and one of the other pins. If/when you find it, take an AC reading between pin 7 and the pin that has continuity with F4.
Stevros
506CR
All voltages correct, thanks for helping a novice, i have learnt by this
Sorry for being a pain
Stevros2014-09-11 21:50:17
