Atari Star Wars probs
Dex-Jay
375CR
Hi again,
After trying a replacement AVG Chip from Biltronix which came well packed and in 4 days from Canada(!) I did think it had improved slightly, but the freezing of play and the spot killer comes on.
Going through the diagnostics a Bad RAM - VG RAM1 AT 3M shows up.
So should I replace the chip at that location, a few of the RAM chips?
Apart from that, bearing in mind I've never replaced any caps on the monitor, what would the reason for the mislignment be with the vectors? The monitor by the way is a WG6100 with a LV2000 board installed (not by me) .
Thanks in advance d00ds!
bbz149
26 (100%)
1,608CR
Good to see there is an improvement
if that ram chip is not socket-ed I would cut it out and install a socket as the tracks are very fragile and if you de solder it and try to pull it out it might lift any tracks under the chip.
I cut them out and with an iron and a little solder you can heat each leg and lift them out very easily
P-Man
International man of mystery
1,273CR
Your BIP adjustment is way out, this is your biggest problem.
The VG ram is reporting bad, but make sure you are getting a nice 5.1v on the test points on the game pcb, especially to the video board. If you are, and the report of the VG ram error is consistent, then replace it...
P-Man2013-03-10 14:27:11
Dex-Jay
375CR
Thanks for the input guys.
There is 5.1V on the test points, just checked and after checking with the manual and about an hours worth of adjustment centre-ing and aligning even with both BIP adjustments there is still the freeze in game play and the misaligned text.
Apart from the 1 one error code on the VG the other hardware checks are OK.
I'm feeling there two of us are going to part company very soon!
Mitchell Gant
888CR
Things like RAM failure and AVG chip failure are to be expected in a thirty year old machine I'm afraid, and are normal part of ownership now. My Empire was turned on today and ran for about two hours, then the graphics started to break up and now test mode shows a vector RAM failure similar to yours. Then my Stargate lost it's high scores and now reports CMOS RAM error. If you've ever tried to run an old car and keep it running ... well it's very similar!
Dex-Jay
375CR
Sure I know what you mean, but my Blasteroids hasn't skipped a beat and my lasergames are as good as gold!
If it wasn't worth so damn much I'd MAME the bejebus out of it and gladly take a sledgehammer to all the original parts!
Dex-Jay
375CR
Right lets give a 6116 a go then!
The only thing that's failing/non working in my place is the SW and my body!
I think I'll expire before any of my other cabs!
