Atari Star Wars... resurrection
yorkshire_spam
765CR
So, my first look at anything arcade related in around 10 years!
The Star Wars isn't working, not really a shock after that long in storage.
The monitor looks like it's powering up ok (I get the dreaded spot, but nothing more) nothing from the PCB set though, no sounds nothing.
A quick check on the PCB voltage test points shows wrong/no voltage.
Fuses on the brick are all ok, so I guess investigating the ARII is the next step. Somewhere in a box I have all the components required to rebuild an ARII, the key word being "somewhere".
I did find my box of spare AR PCBs though. It turns out I actually have 2 ARIII boards, and 3 ARIIs.
1 of the ARII PCBs is fully populated, but has bad burn damage in the usual places. The other 2 don't have the right areas populated for Star Wars.
I never stop being annoyed that Atari left places on the AR boards for test points and then didn't fit them.
Anyway, I'll do a bit of reading around the ARII and then get testing.
Cheers,
Sam
yorkshire_spam
765CR
AnDyC said:
Hey spam , long time no speak.
Yeah, I've been busy!
yorkshire_spam
765CR
Well I can confirm that kneeling at the back of the cab trying to troubleshoot is a crap way of doing it. I wish I had a test bench like the "good old days"
I started getting some sounds (sounded like the tank sound from Battlezone!) but not much else.
I seemed to be getting somewhere with a spare ARII I found in the back of the BZ cab, but when I checked the 10.3V un regulated going into the ARII was all over the shop... so now attention turns to the power brick.
Any idea how spot on the voltages need to be on a SW?
Can I get away with +4.8 on the +5 or does it need to be spot on?
Time to start searching through boxes for parts!
Cheers, Sam
ColinD
6 (86%)
1,367CR
Hey Spam, there is a vector pre flight check thread here somewhere, with many checks for the monitor. I remember this cab when it was in Liverpool.
You are right to check the ARII first, hopefully it will already have the sense mod. I've seen extra power cables 'jump leaded' from ARII test points to the pcb test points with 1/4" crimps (bypassing/parallelling the edge connectors) to give a more solid supply etc. Not sure how close the 5v would need to be but I usually go for around 5 to 5.1 V.
yorkshire_spam
765CR
Thanks Col. I'm going to pull the power brick and check that over, sense mod the ARII and replace the regulators. I ran over the stuff in the previous flight, but voltages etc seem flaky rather than wrong. I hope its the connectors and not the brick transformer melting down.
(I sold my spare colour vector brick years ago, to luke in Blackpool maybe? I forget)
Cheers Sam
yorkshire_spam
765CR
Hmmm could be BAD news. I pulled the brick and I'm getting VERY wrong readings on J5.
+50V on the 10.6VDC line... well over 100VAC on the 36VAC lines.
I checked and it has the right coloured voltage selector plug installed.
Anyone know what the transformer winding resistance are from a known good?
I might end up searching for hens teeth, rocking horse poo, and Atari colour vector power bricks.
yorkshire_spam
765CR
Anyone know how the secondaries are wound on these transformers, I'm wondering if I could re-wind one of the secondaries on a colour raster transformer to give 25-0-25VAC instead of 30-0-30VAC, as far as I can see that's the only difference (and the pin assignment on J5)
Cheers,Sam
yorkshire_spam2018-04-20 14:00:34
tb lilley
5 Star
1,686CR
I struggled to find a brick for Tempest. Eventually gave up and instead spliced a 25-0-25 toroid transformer into a Centipede brick (just hacked the wiring on the underside of the brick). It's not pretty, but is effective and has been running fine like that for best part of 6 years ..... Cheap and simple too. Toriod just taps off the 240v brick input for its power.
