I have Marble Madness cart with a Atari System 1 LSI main PCB the comes up with a 6502 Not Responding. Any ideas? I can't find a 6502 chip on the main pcb.
The 6502 on the LSI main board is @ 16J/K.
The 6116 rams chips are @ 14L & 15L
The Pokey chip is @ 17J/K.
I have had a board in the past that had 6502 not responding when a failed Pokey chip was used but also agree that the ram chips are also a good posibility as well as the 6502 itself.
Every was working fine then the power supply (switching) died. Replaced with the same exact model switching power supply and now getting the error. When I put Roadrunner cart in it boots up fine.
Just ordered a new 6502. I'll start there then try the other options.
RAM would be a good next step, usually one of the 6116's is socketed and one is soldered. But beyond these there are a few TTL that are involved with the communication to the 68K, 74LS138, 74LS139, 74LS32 & 74LS74 are the main ones if I remember correctly.
