Atari System 1 Multiple Cartridge High Score Save
GadgetFreak
952CR
If you have an Atari System 1 and multiple carts it will reset the NV memory every time you change cartridge. Strangely though, Atari did actually design the board to allow the NV socket to accept a 2816 even though they only used a 2804. This patch along with a 2816 will allow your main board to keep all the scores/settings for all 5 available cartridges at the same time.
You will need to patch either the 205/206 or 114/115 bios eproms on your system 1 main board and replace the 2804 at F15 or E13
As with all my High Score Patches, please post a reply or click thanks if you find this patch works for you.
136032.205.l13
Code:
[b]26F5: change these bytes  43 00 00  to  4E 00 7D[/b]
[b]2734: change these bytes  43 00 00  to  4E 00 7D[/b]
[b]2790: change these bytes  35 00 25 00  to  4E 00 7D 4E[/b]
[b]27D2: change these bytes  47 00 00  to  4E 00 7D[/b]
[b]
[/b]
[b]These bytes should all be 00 before you changes them.[/b]
[b]3E80: 48 20 74 14 00 00 0C 00 66 00 53 C4 03 43 00 00[/b]
[b]3E90: D2 4C 00 4E 48 20 74 14 00 00 0C 00 66 00 53 C4[/b]
[b]3EA0: 03 47 00 00 D6 4C 00 4E 48 20 74 14 00 00 0C 00[/b]
[b]3EB0: 66 00 53 C4 03 93 35 00 25 00 4C 00 4E 4C[/b]
136032.206.l12
Code:
[b]26F5: change these bytes  F9 F0 01  to  B9 00 00[/b]
[b]2734: change these bytes  F9 F0 01  to  B9 00 00[/b]
[b]2790: change these bytes  49 16 48 18  to  B9 00 50 71[/b]
[b]27D2: change these bytes  F9 F0 01  to  B9 00 28[/b]
[b]
[/b]
[b]3E80: E7 00 00 39 01 6E 02 05 00 04 02 FC 00 F9 F0 01[/b]
[b]3E90: C2 DF 04 75 E7 00 00 39 01 6E 02 05 00 04 02 FC[/b]
[b]3EA0: 00 F9 F0 01 C2 DF 04 75 E7 00 00 39 01 6E 02 05[/b]
[b]3EB0: 00 04 02 FC 00 C2 49 16 48 18 DF 04 75 07[/b]
Or
136032.114.j11
Code:
[b]2377: change these bytes  43 00 00  to  4E 00 6F[/b]
[b]23E0: change these bytes  43 00 00  to  4E 00 6F[/b]
[b]242C: change these bytes  35 00 25 00  to  4E 00 6F 4E[/b]
[b]246E: change these bytes  47 00 00  to  4E 00 6F[/b]
[b]
[/b]
[b]3780: 48 20 74 14 00 00 0C 00 66 00 53 C4 03 43 00 00[/b]
[b]3790: D2 4C 00 4E 48 20 74 14 00 00 0C 00 66 00 53 C4[/b]
[b]37A0: 03 47 00 00 D6 4C 00 4E 48 20 74 14 00 00 0C 00[/b]
[b]37B0: 66 00 53 C4 03 93 35 00 25 00 4C 00 4E 84[/b]
136032.115.j10
Code:
[b]2377: change these bytes  F9 F0 01  to  B9 00 00[/b]
[b]23E0: change these bytes  F9 F0 01  to  B9 00 00[/b]
[b]242C: change these bytes  49 28 48 2A  to  B9 00 50 71[/b]
[b]246E: change these bytes  F9 F0 01  to  B9 00 28[/b]
[b]
[/b]
[b]3780: E7 00 00 39 01 6E 02 05 00 04 02 FC 00 F9 F0 01[/b]
[b]3790: C2 DF 04 75 E7 00 00 39 01 6E 02 05 00 04 02 FC[/b]
[b]37A0: 00 F9 F0 01 C2 DF 04 75 E7 00 00 39 01 6E 02 05[/b]
[b]37B0: 00 04 02 FC 00 C2 49 28 48 2A DF 04 75 07[/b]
GadgetFreak
952CR
I actually came up with this patch at the end of last summer, I did post a thread on this forum but no one seemed interested at the time. Anyway as I am now posting lots of High Score patches I thought I should post this too. I haven't posted it anywhere else, so feel free
Digimon
133CR
Thanks, I will do it in all my System 1 Main PCBs.
(But I run out of 27128
for Peter Packrat an Indy.
And everthing should be prepared for the Multi Kit...
Digimon
133CR
Did it on another Main Board, without removing out of the cab.
This time it was the TTL Version.
Works perfect, thanks for the cool stuff!
Valtric59
14CR
When i read this topic, i remember that the st-v system resets the scores when you change the cart, or when the cart is not detected when you poweron the cabinet (when cart moved a little when cabinet powered off)......
