Atari VCS to vga
chubsta
547CR
Just wondering if this would work as i want to make a bar top out of a vcs console and an having trouble getting a bar top kit that would fit a small portable tv, plus using a small via monitor would obviously make it lighter to move about.
Anyway, i have done a composite mod on the vcs so it now has two outputs - composite video and audio via the usual two connector jacks. If i plug these into one of those composite to scart connectors that you can buy for a couple of quid off eBay then it works via the scart socket on the tv. so far so good.
I also have a cga to vga board lying around doing nothing.
I have also made some small jamma to scart boards to allow me to connect a jamma board to a scart tv.
so, working backwards from this, does anyone think the following would work:
1. connect the composite leads from the vcs to the composite to scart connector.
2. connect the composite to scart connector block to my jamma to scart board (I presume i would have to change one of the pins at the scart connector so it runs 'out' instead if 'in'.
3. connect the pins for rgb gnd and sync from the other end of my jamma to scart board to the cga to vga connector.
4. connect the vga out from that board to a monitor.
effectively i am trying to run the jamma to scart connector in reverse.
Any and all advice appreciated!
chubsta2014-04-04 09:49:07
