Avoiding System22 / Ridge Racer Texture Issues
G
Guests
Guest
I've heard (and seen) that System 22 boards suffer from texture issues over time and I've been told this is down to heat.
Is there anything i can do to stop this happening on my board? I was thinking of buying a ton of heatsinks and fit them onto various chips but I'm unsure which ones would need it? CPU? GPU? GRAM? Any others???
Don't want mine to fall into the same fate as many others seem to have done and no one seems to know how to fix these issues either as Namco stuff is pretty specific stuff so really want to try and avoid this happening.
Any idea's/advice?
Smraedis
105CR
I have a Time Crisis 1 (System Super 22) with the common graphic faults, the pcbs have clear heat damage, but the fan was mounted the wrong way round, which can't have helped.
I would say that make sure the fan is working and don't leave it on all day long, and it shouldn't get too hot. From what I've heard, Time Crisis 1 seems to be the worst for having graphic errors and the Ridge Racer series doesn't seem to have anywhere near the same problems.
G
Guests
Guest
Yeah my cab has the original fan it had on it since birth i think.. i've had it off and cleaned it and the cab is only used now and then these days it's never left on all day so it's highly unlikely that it will have any problems I'm just making sure really.
Strange how Namco allowed this to happen. Is it old age or a design flaw?
Do you know what actually fails when the texture issues occur? I'm pretty interested in knowing more about these boards.
