B+ on MTC9000 drops gradually
big10p
Coins detected in pocket!
6,093CR
Been having all kinds of trouble keeping this chassis alive (as Grant will testify). Think I've made progress today when I changed C34 simply because the solder joints looked dodgy. I only had a used cap to replace it with and don't have a cap meter yet (on order) so was unable to test either one. This is how desperate I've become.
Anyway, I'm now at least getting something on screen, but the b+ still isn't right. Starts off at about 113v and gradually decreases at a rate of a fraction of a volt every few seconds, or so.
Anyone come across this before and know what else I should be looking at?
Cheers.
big10p
6,093CR
Hmm, I didn't know there was a pot for b+ adjustment, TBH. Sounds like a likely candidate. Any idea where it's located?
big10p
6,093CR
OK, there's no b+ pot on this chassis. I've noticed adjusting the h-sync pot affects the b+ voltage, for some reason. Checked through the schematic and metered loads of components (out of circuit), re-flowed joints, checked for cracks and broken tracks.
big10p
6,093CR
With h-freq turned fully left, I get 107v on b+. Fully right, I get 80v.
Either way, the chassis does seem to be kind of working, as I get neck glow, but it's very faint. With the signal cable attached, I get the image below on screen, but it's very faint too, and can't be seen without turning the room lights off.
big10p
6,093CR
Yes, I have an MTC 9000 in another cab. I'll try it with that.
Interestingly, I don't think the tube with the non-working chassis is an original MTC 9000 tube, as it has neck rings, whereas the tube in my other cab doesn't. I read somewhere that MTC tubes don't have neck rings. The one with rings has 'Hantarex' and 'Orion' labels on it.
big10p
6,093CR
Well I never! Chassis works fine in my other cab. Solid 131v on b+. This chassis has been driving me mad trying to fix it - turns out there's nothing wrong with it!
So, this tube is knackered and beyond repair, do you think?
Thanks again for your help, Grant.
tb2000
3,584CR
That'll almost certainly be a knackered yoke causing that then. Yoke is easily replaced though if you have a spare. Typical Orion tube problem, i've had a number of them with shorted/faulty yokes! They all work with all chassis though (900/E, 9000, 9000/A, Polo), but the neck rings thing doesn't matter. They were sold with a variety of tube makes, Orion, Videocolor, RCA, ITT all seem to be the main ones. Some (such as Videocolor) used a computer at the factory to do the convergence (they have a thin magnet round the neck) and others used the standard rings set-up.
tb20002015-11-30 22:45:15
gunblade
9,144CR
yep looked like yoke as you can see the three colours splitting off at a wierd angle
photo of the neck and deflection yoke area of the bad crt please
big10p
6,093CR
Cheers for the info, chaps. I don't have a spare yoke, unfortunately. I tried to take pics from all angles. Let me know if you need a close up of a certain area.
Cheers.
big10p
6,093CR
So, if this yoke is knackered, just how easy are they to replace? Looks a bit of a nightmare to me. Are there any tutorials or videos on how to do it?
I also don't know where I could get a replacement from, or what type I need to get. Bit lost here, TBH. Any help appreciated.
Thanks.
tb2000
3,584CR
I can't see any burnt areas on your yoke but to be honest if there was then you almost certainly would've had ticking coming from the chassis and/or smoke from the burnt area! They are pretty simple to change. Ideally you need another Orion yoke but yokes from other make tubes will work. What you need to do is to undo the jubilee clip on the rings on the neck and gently remove them, then undo the clip on the yoke and slide that off the neck. Sometimes you'll find that the rings are stuck pretty well to the neck due to years of heat from the neck. Also, they sometimes can be quite brittle so they may fall apart on removal if you're not careful. Sometimes it's just impossible to get them off without breaking them. If you do break them, the job gets trickier as then you'll need another set of rings and will need to set them up. The yoke replacement is easy though - when you have a replacement, refit is the reverse of removal. You'll need to adjust it with the monitor switched on, preferably with some kind of test image like a test card from a 60-in-1. An all green screen is handy for setting yoke position also. There will be a sweet spot on the neck where the yoke sits, if it's too far one way or the other you will have colour impurities - this is if you have the original rings refitted where they were before. If you don't then you need to set the new rings all equal to each other (so the magnets cancel each other out) then set the yoke, then set the convergence and purity on red to green then blue to green. Bit of a task but it is possible (sometimes it's just not possible to get it bang on though!)
tb20002015-12-02 12:01:21
big10p
6,093CR
Thanks very much for the explanation. Not sure I like the sound of adjusting the yoke with the monitor on, though. Yikes!
Looked on ebay for a yoke but didn't see anything suitable. Do you know of anywhere or anyone that might have one?
Thanks.
big10p
6,093CR
OK, I've taken off the ring assembly and yoke. Both came off easily but the ring assembly didn't survive - it just crumbled away when I unscrewed the jubilee clip:
There is evidence of burning/shorting on the inside of the yoke. There was also a load of small metal strips and paper on the inside. Presumably these are convergence strips? If so, I have no hope of getting them all back in the positions they were in.
Worryingly, there's also some kind of liquid inside! I can't tell if it water, oil, or whatever, but presumably it shouldn't be there and is the cause of the shorting?
Any help or advise where to go from here would be great!
big10p2015-12-02 23:39:20
tb2000
3,584CR
If the rings themselves are still being held together you may get away with reusing them, just use a little hot glue to get them back on and held. that spot where you show the "liquid" is almost certainly the point of failure. The corresponding spot on the yoke where you can see the burning - the wires will have heated up when they failed and melted off the protected coating applied to the copper wire beforehand. Don't worry about the bits of paper inside the yoke, they just hide tiny magnets and are specific to that yoke, and were applied at the factory.
I may have a spare yoke but to be honest at the minute I have at least 3 or 4 tubes of my own without yokes (Orion tubes not surprisingly!) and rings - any yokes and/or rings i've kept off of scrap tubes I have kept for those.
tb20002015-12-03 00:14:24
big10p
6,093CR
Ah, I didn't know the copper wire had some kind of coating on it. That explains a few things. That rules out just cleaning/drying the yoke and expecting it to work again then, does it?
The rings are still held together - just the little tabs broke off - so hopefully I can re-use them, then.
I have no idea where that liquid came from, BTW.
Doesn't sound like these Orion tubes are much cop, then. No worries if you don't have a spare yoke, but please let me know if you hear of one for sale.
Thanks.
tb2000
3,584CR
Yep, you can't really do much with that yoke unless you feel like unwinding the wire and recoating the wire, then rewinding it! The insulating coating (as far as I know anyway) is there specifically to stop the wire shorting out on itself. Sometimes this breaks down and you get the result you've ended up with on your yoke. As I say, the liquid drip you can see is almost certainly from where the insulating coating melted off due to heating up from shorting out. I think maybe Orion had a bad batch of yokes or a wire coating problem at some point. I even had a 20" TV with a yoke go wrong and it was an Orion tube. That said, they do produce as good a picture an anything else when they're working. I suppose you could say it's got an excuse to go wrong after maybe 25-30 years although I have plenty of other make tubes or similar age with yokes that are still fine!
