Baffling Power Issue
Purity
The Oracle
17 (100%)
2,999CR
I'm really baffled by a problem I'm having, and maybe someone can provide some explanation
Basically I'm having troubles booting a Double Dragon bootleg on my Jamma Supergun (switcher) setup. This setup is literally just a switcher with a jamma loom
However it boots everytime on a Vogatek supergun with ATX power supply!
So I compared voltages, at the edge connector and the switcher looks better, but it still won't boot!!! Could it be that the Vogatek smoothes the voltage out a bit more that the jamma supergun setup?
Here are the readings:
Vogatek Supergun
+5 = 4.94-4.95v
+12 = 12.30
-5 = -4.93
Jamma Switcher
+5 = 4.96v
+12 = 12.76
-5 = -5.70
I also took several readings across both boards at
CPU - 1A, 1T, 7A, O5
Video = IC141, IC18, IC122, IC1
The voltage ranged from 4.75v-4.87 on the Vogatek. On the switcher the voltage was slightly higher on all counts
Any thoughts on this would be appreciated, as it is driving me nuts :)
Purity2016-05-24 18:55:30
Purity
The Oracle
17 (100%)
2,999CR
Yes they do. The only other problem board I've come across is a PlayChoice10 PCB. Doesn't boot on the switcher, but works fine on the Vogatek
PaulSwan
ZZZ
1,118CR
Possibly you have a bad reset circuit or the board doesn't like a slow power ramp up. To see if it's this, manually trigger the reset circuit and see if the board boots up.
Paul.
Purity
The Oracle
17 (100%)
2,999CR
Paul.
It does seem to be a speed of reset issue.
Pulsing pin 39 on the hd68b09 @ IC41 does get the game booting
Not sure what I could do about it though? Not sure if it is too fast or too slow as yet
Purity2016-05-24 20:36:59
PaulSwan
ZZZ
1,118CR
You could try changing the switcher for another model.
Another option is to put in a 3-terminal reset IC (DS1233) in place of the RC circuit. I've done the latter before myself for the few boards that don't like my bench-top switching power supply (Vanguard was one such board).
5,413CR
I had one of those Hanty monitors with the built in jamma psu, that was crap, stick a bootleg pcb in and it wouldn't work. couldn't turn the voltage up enough for them. stick same board in old Cocktail cab and it was fine
Think i'd try another
Purity
The Oracle
17 (100%)
2,999CR
Switcher should be decent. It's one of the ones Ordyne sells/used to sell (Rodotron?)
I have some Chinese ones, but doubt they will be any better. I can certainly give it a try and see if it makes any difference
Purity
The Oracle
17 (100%)
2,999CR
PaulSwan said:
The PST518 looks basically the same idea - 3 terminal reset thing - so that should be cover you. I wonder if you have a fault in your reset circuit?
Wouldn't have thought so as the pcb boots and resets perfectly everytime on the vogatek
