I am trying to fix a Bally MPU Board with a locked on LED using the late great Leon Borre’s test Eprom at position U6 and the 6800 CPU chip in position U9.
Following his instructions it says connect the test Led, negative to pin 15 of U9 and the resistor lead to TP5.
However reading this Old Pinball Guide, it says connect the resistor lead of the test Led to pin 15 of U9 and the negative to TP4
So can anyone explain the difference between these write ups as I am getting a little confused at the moment.
Thanks All
Thanks All
