Bally Vector log
Deathrow
Boom boom POW!
140CR
Well here is my first machine...
Its a complete dog to be honest and far from being as described.
I have never owned or repaired a pin before.
She was bought not coining up and with several issues.
This is all she did when turned on:
She has a new mpu and you can get into test modes and get some features and sounds to function but she's pretty sick and dim lamps etc.
Found the earth to the upper cabinet wasn't connected to anything.
Nice bright lamps and the mpu will run through its tests correctly.
I decided to give her a shake down.
First up it had no balls (added balls)
Wouldn't coin up? Re-soldered the cut wires from the switches and replaced the connector from the loom. Now accepts old 10p's and gives credit.
Game wouldnt start?
Hmmm, set to work and found a fault on the tilt meaning the game wouldn't function or load the first ball.
cut the offending diode out for now to remove the tilt function.
Ok so I could get the game to start but no flippers or solenoids so had to manually enter the ball into game. Lets take a look at the Driver.
I got two with the machine, Both horlix'd
Started on the best of the two and replaced:
Checked the voltages and I now had the 5v to the transistors.
A nice working board set up
Next I ran a full test and still had some solenoid issues on the PF.
Turned out to be the solenoid expander relay board on the underside of the playfield.
A couple of switches cleaned and I now have a nice bright and fully working vector
Will Upload a vid when I can play her with correct size pinballs to avoid damage.
Deathrow2013-06-26 22:42:21
Deathrow
Boom boom POW!
140CR
This next part is where I should never trust whats fitted to a machine as being correct.
After fixing the last of the solenoid driver board issues and repairing a second board I found I had a problem with a coil on the top saucer hole.
I removed the offending coil and replaced with a like to like from Pinball heaven.
The coil arrived in good time but also burnt to a crisp even faster! I had replaced the drive components before fitment so was a little puzzled.
I was checking the wiring again and again through the Circuit Lie-agrams and I even checked every diode I could find. It was then that my lovely assistant pointed out the numbers on the diagram were different to that on the coil!
Some silly fool had used a twin winding coil in place of the original single.
The playfield.
The wrong coil:
(This is the new replacement I burnt £15 quid on in an insatnt lol)
This is what should be fitted:
The better half found a place online with some genuine bally coils (used) for a couple of notes each. Will give an update when they arrive.
http://www.coin.demon.co.uk/
Deathrow2013-06-26 22:48:03
Deathrow
Boom boom POW!
140CR
Sounds:
I thought I had the sounds licked but I was getting a couple of issues so I got hold of another sound board. I was swapping the chips over and noticed some of the legs were missing.. Found the problem then!
I got the ol honkey tool kit out and went to work.
The wife with better eyes then me cut some very small welding wire strips and I soldered them to the offending legs.
Its hard to get a picture of the pins on the chip but if you look at the two bottom pins on the second sound chip then you can see the wire legs and solder tips. (you can honest)
And what a mouthful this old box can say:
There are a couple of phrases that I have found in there that are not used in the game anywhere.
Here is a pop quiz for the Anorak types
Answers on a post card to - Blue peter po box.........
Deathrow
Boom boom POW!
140CR
The coils turned up today (bought two so I had a spare just incase lol).
Original Bally coils.
swap time:
Just to be on the safe side I removed all components linked to the coil and replaced the lot.
Don't want the replacement to burn up.
AND........WOHOO! I have a full house of coils!
Deathrow
Boom boom POW!
140CR
I think I am going to re do all of the board connectors next. Does anyone have any they can sell before I place an order or maybe some advice?
Deathrow
Boom boom POW!
140CR
alomost time to strip it right down.
A few GI problems and a few iffy bulbs etc to sort first.
maybe I should just leave it as a useable machine and not mint it up? what do you guys think?
I like to fix them up more than tart them up.
1, Trade up once working for a newer broken machine
2, Strip her down and go for a full rebuild
3, Just get it all working and patch up the mylar etc
4, I dont care I dont play pins anyway
What do you guys think?
Deathrow
Boom boom POW!
140CR
Alpha1 said:
Cor, I'd go for 2, but 3 is the middle ground!
How's she playing?
Playing really nicely mate, Nice strong coils all round and all of the functions work including the multi player.
I have noticed a fault brewing on the centre top board display so will prob give this a look too.
Ive seen some of the work you guys do and I think if I am going to tackle something like that then maybe I would want a newer more involved machine? The Vector is no IJ in anyones mind.
Its actually a good game for an oldie and the strict rules have kept me interested in it but I have enjoyed the fixing and bringing it back to life more than the playing.
Decisions decisions....
I have seen a couple of newer machines on ebay that have my eye, If I had my way (and the money) and would own more than one pin at a time.
Deathrow
Boom boom POW!
140CR
when I bought this I was promised by the seller that the "missing parts" that were not there upon collection would be sent to me ion a day or two but one month later it looks like the less than reputable person has failed to deliver.
Its a shame but not a shocking revelation.
If anyone has an original MPU for one of these then please get in touch.
I would like to get the machine back to original where possible.
I would happily give a drink to anyone who helps with a lead to an original MPU board.
