Bank panic prom
Shinydaz
814CR
Missing a chip here on bank panic (2:C), does anyone know if it should be:
315-5073.pal16l4 as it doesn't contain location data like the other roms do.
I need to get my test bench set up again, to get roms verified.
Thank-you Shinydaz2021-01-24 13:15:12
yorkshire_spam
765CR
Assuming it's not just a random empty socket on the board, there's 4 "prom sized" files in the mame romset, so if you've ruled out the other 3 I guess it's a good chance that's the one?
2C is populated on the images of the PCB that I can see online, but none are high enough res to see the markings on the IC.
Ace`
PlanB contributor #1
40 (100%)
4,040CR
315-5073.pal16l4 is read protected and undumped according to mame, I might be able to brute force it as I have a working Bank Panic board.
Shinydaz
814CR
I don't even think that 315-5705 is the correct prom for starters, I maybe wrong. Is there only 1 set of bank panic roms dumped?Shinydaz2021-01-24 16:12:15
yorkshire_spam
765CR
If it's the 315-5704 as per the PCB image I pulled off the interwebs it's not a PROM - it's a PAL10V8 device.
Which is probably why the file in the MAME roms ZIP is a jedec rather than a binary rom image.
