Bank Panic sound issues
mappy24
43CR
Hi,
I've got a Bank Panic PCB that's outputting sound that's not very loud and when you turn up the volume on the board some of the sounds are distorted. The board has already been recapped and interestingly, if I hook it up to the Supergun (one of TheLastBandit's) and flick the audio switch to the MVS setting, the sound is loud and perfect!
I'm starting to suspect the JAMMA adapter, it's got pin Y going to Speaker+, pin 21 going to Speaker- and both speaker ground connections on Z and 22 are connected to JAMMA ground.
Has anyone got a Bank Panic JAMMA adapter they can compare to mine?
Thanks!
Ace`
PlanB contributor #1
40 (100%)
4,038CR
I'll take a picture of the back later (this is an old picture). Before anyone says anything I added the video ground wire after the picture was taken.
Ace`
40 (100%)
4,038CR
It's just jumpered to a jamma ground, it's proably not needed but I like to add video grounds to all my adapters as it can cause problems if it's missing.
