Bar top unit help needed
Jinge1
1CR
Hi guys really pleased for the add. I’m in need of some help and advice . I have a bar top arcade unit built for me by a friend it has a modified original Xbox inside and was running a programme something like hyper spin not sure exactly but the console inside has died. My technical knowledge is zero is there something I can swap with to continue to use my unit or does anyone know anyone in the Southend or Essex area that could help my knowledge us zero I can’t stress this enough sadly my friend is terminally ill so this would be the last thing on his mind. Any help or advice would be amazing and greatly received.
Thank you in advance
Friedgoat
27CR
Hey there,
When you say the console has died, do you mean it doesn't come on at all? Can you hear the HDD spin up? Does the LED on the front light up (green)?
I'm assuming it's running a chip like an Xecuter, there might be a little panel stuck to the front of the XBOX, does that light up (blue)?
Jinge1
1CR
Hi thanks for your response the console comes on with the original Xbox logo but then does nothing . The screen just goes blank I managed at one point to access the original Xbox menu and it showed files but would not run anything
I hope this is a bit more helpful
ZedEx48K
8-Bit
1,425CR
It will be running coinops, your best bet will be to access it via FTP, if you can do that you can change the default dash boot etc, for more information googling a guide would be your best best.
https://www.youtube.com/watch?v=ovU3wwrKABM
https://www.youtube.com/watch?v=xlMWfAayvkU
There's 2 examples
Friedgoat
27CR
Interesting...
does it have a little panel stuck to the front?
It's hard to give any advice when i'm not sure if it's softmodded or chipped etc..
I would start with reseating the cables to the hdd I guess....
If it's chipped I would suggest looking at where the wires are soldered to check the connections...
If it's an Xecuter 2 you will have about 4/5 wires to check on the top of the Motherboard, and one that runs underneath.
