Battlezone DACs
yorkshire_spam
765CR
Hi all,
I'm more used to DACs wired in very simple configurations... 2's complement allowing a range between V+ and V- on the output etc etc.....
But I'm a bit baffled by how the 6012 DACs are wired up in the Battlezone output circuit
I'm seeing plenty of clean 1/0 activity on the digital inputs, but very little voltage variance on pin 18 (which I think is the output?)
Anyone got any idea how much voltage swing I should be seeing there?
I'll probably end up pulling the 3 dacs and socketing them anyway, but if I could figure out if they are working first that'd be great!
Out of interest (while I'm here) anyone know what the output range is for X-out and Y-out on the same PCB? I'd assumed around +/-15V due to the supply of the op-amps/DACs but now I'm not sure....
Confused of Halifax
yorkshire_spam
765CR
Yeah, I checked out the datasheet and I'm using a scope, but give that I can see the high bits toggling cleanly on input I'm wondering how much swing I should see in the output, the way the thing is wired into the circuit is confusing me. (Tiny brain)
Mitchell Gant
888CR
You won't see any decent voltage swing on the output with a scope as they're *current* "output" into a virtual ground of an op amp input.
They aren't even really an output either, but a current sink from the bipolar (BIP) current source circuit.
That programmable current then charges/discharges the 47nF capacitor to a voltage level with a smooth ramp, which in turn draws the pure analogue vector line on the monitor.
I think it gives a monitor output voltage swing of about +-8 or 9 volts though I might be wrong there.
RGP
Meeter & Greeter
2,039CR
If you're ever stuck, lift out the op-amp in line with that DAC and then look at pin 18 and you'll see a slightly more sensible signal - nothing like you want but at least a better indication of which way to go.
I tend to just shotgun the entire section as man-hours wise its just faster.
This didn't go too well for me though on a Star Wars board as the DAC's I had got were a bit chinesium quality so the problem persisted with the "It can't be the chips, it must be the analogue parts" kind of persistence.
I know now and won't be using eBay TL082's and AM6012's - they're still available by tubes - i'm guessing limited supply but i've refreshed my stock as a precaution.
Neil's right about that 47nf cap though - that seems to be the entire drawing circuit via its charge/discharge cycle - we believe that the composition is important but not fully proven so not just any 47nf in replacement will do.
Neil can explain that part a bit better than me.
yorkshire_spam
765CR
Thanks guys, the critical nature of the capacitor was mentioned in Secret Life of Vector Generators by Jed Margolin which Col forced me to read! ;-)
I'm just waiting for some parts to arrive before I go the shotgun route. DACs I already had, but switches and op amps I didn't.
ColinD
6 (86%)
1,367CR
Yes, useful to know how it all works.... I believe you can use DAC312 instead and they are more easier to obtain, think there are subs for the analogue switches too.
Mitchell Gant
888CR
DAC312 are substitutes for the AM6012 DACs as Colin says:
https://www.mouser.co.uk/Analog-Devices-Inc/Semiconductors/Data-Converter-ICs/Digital-to-Analog-Converters-DAC/DAC312-Series/_/N-4c44d?P=1yyge95Z1yyh4l4Z1z0y31mZ1z0y33v
I've seen a few failed DAC's on these boards.
The LF13201 analogue switches can be substituted with ADG201 :
https://www.mouser.co.uk/ProductDetail/Analog-Devices/ADG201AKNZ?qs=BpaRKvA4VqFnqwUKWzVPLQ%3d%3d
Not seen too many failures of the analogue switches, but seen plenty of TL082 op-amps failed.
I've used Polyphenylene Sulphide (PPS) composition for the 47nF capacitors, as polycarbonate are getting hard to find now.
https://uk.farnell.com/kemet/smr5473j50j01l16-5cbulk/cap-0-047-f-50v-5-pps-radial/dp/2529183?st=47nF%20PPS
ColinD
6 (86%)
1,367CR
That's great info - Thanks
ADG201 certainly rings a bell and sure I have used those, but its been quite a while since I've poked and prodded vector generators !!
Those caps sound interesting and a new one on me, would that type work in Star Wars too ?
I'd forgotten, but the Braze Technology Kit works well and save you buggering about with roms / rams and IC sockets, I had an issue with mine for some reason back in the day where it wouldn't work correctly but think it did test mode ok... he came up with a fix for me, I reburnt the eprom and it was fine after that.
Basically Battlezone is split into 3 sections which can be further split down.... CPU (Ram/Rom/IO) , Vector Generator (Digital State Machine and Analogue Generator) and the Aux Board (Mathbox / Sound and Control Panel Inputs)
ColinD2018-12-29 17:25:40
yorkshire_spam
765CR
The manual, schematics and "Secret life...." state Mylar caps used in Battlezone, but not others.
"Mylar Capacitors were used in BattleZone, but did not work very well in Star Wars, which had a faster drawing speed. The capacitors that worked the best for us in Star Wars were Polycarbonate Capacitors.
Polycarbonate is a clear and colorless amorphous thermoplastic notable for its high impact resistance. In addition to its use in capacitors it is used in glazing, safety shields, and CDs. (An excellent Web site for the properties of materials is http://www.goodfellow.com/.)
Polystyrene capacitors are also considered high quality capacitors but they worked poorly in the Integrator.
The properties of polystyrene are similar to polycarbonate but for reasons that are unknown the polystyrene capacitors exhibited problems that appear to be the result of charge redistribution."
ColinD
6 (86%)
1,367CR
Making of a good padawan spam you are ;-)
However... buggered if I know what caps are good for Starwars - I'm all ears as is Master Yoda !!
Luke... use the Polycarbonate Capacitors !!
ColinD2018-12-29 17:35:14
yorkshire_spam
765CR
Well I should be back on the BZ today or tomorrow.... Missile Command is up and running, but trackball is faulty (waiting for parts) and the Crystal Castles is working... so back to the BZ!
yorkshire_spam
765CR
So I finally socketed and shot-gunned most of the silicon on the vector generator.
I have -ve output on X and +v output on Y but not the inverse.
I suspect the XREF/YREF/XBIP/YBIP driven by DAC08
Possibly dumb question - what voltage (if any) should I see on pin 14 (VR+) of the DAC08@C9?
The effective resistance of R80/R81 (7.5K each in parallel) is about 3.7K measured with the meter - which seems about right. But I see 0V at pin 14.
Any pointers?
Cheers,
Sam
Mitchell Gant
888CR
Any pointers?
Not a dumb question, as it's a confusing circuit!
Although pin 14 is listed as Vref, the two 7.5K resistors are current limit resistors to provide a current source to the DAC, so you'll probably see next to no voltage measured on pin 14.
I've not confirmed that on a real PCB though, just my guess from looking at the schematics.
yorkshire_spam
765CR
Hooked it up to the scope:
This is XOUT inverted (green) and Pin 2 of B10 (yellow)
This is YOUT non-inverted (green) and Pin 2 of E10 (yellow)
As per previous comment I only get -VE deflection in X and +VE in Y
Back to studying the schematics!
yorkshire_spam
765CR
I wonder if the "sign" bit is not working.... hmmm. Back to secret life to see if it indicates is MSB or LSB on the dacs is the sign in the 2s complement...
yorkshire_spam
765CR
replaced Q2.... I now have what looks like an attempt to draw the screen with +ve and -ve Y outputs, but mostly +ve X outputs..... :-(
Bearing in mind I'm using a simple USB scope with no Z-Input. I'll have to fetch one of the proper scopes from the shed at some point and get it working.
