Battlezone screen flip
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I bought the battlezone cabaret that was for sale on here a coupe of month ago. I have had the pcb repaired and tried it for the first time tonight. All plays fine apart from the screen needs flipping from left to right. It doesn't seem like there is a dip setting to do it.
Can anyone help to tell me how to flip the picture?
I know the upright cab has a mirror but the cabaret does not.
Cheers.
Steve
Pics as requested after fixing with all your help.
Steve2015-02-01 22:21:38
4,058CR
Nope, you really don't need to try messing about with Yokes, it's a VECTOR game, not a raster one.
If you look at the schematics for both upright BZ and cabaret BZ you'll find that the pinouts for the Vector PCB (the main, big one) has a connection between pins P & L. L being X INV and P being GND. So basically, GND pin P to invert the picture.
I would have thought this would be done by the loom in the cab if it is a cabaret. Check if it is or not.
If grounding that pin makes no difference then the XINV circuit on the PCB is not working. I'd have thought that to be fairly unlikely though to be honest, especially if it's just come back from repair. IIRC my test loom has an invert switch specifically there to test this on BZ.
4,058CR
Thinking about this, you may be able to invert the X by swapping the yoke wires but DONT. That will confuse the hell out of anyone that uses that monitor further down the line and could even be whats going on here, but I doubt it since I'm not aware of any cabarets that use mirrors.
Use the PCBs invert connection.
bonehead
50 (100%)
1,729CR
Ok. I had the same problem with a 19" monitor I bought for my asteroids upright.
I was told to swop a couple of wires in one of the plugs which if I remember was connected to the yoke.
The edge connectors have been changed on the loom so do not correspond to the original labelling on the plastic connector.
I will check again tonight if I finish work earlier enough and see what I find.
I was hoping it could be as easy to swop as the monitor in my asteroids :(.
Cheers.
Steve
4,058CR
Steve, this should be easy. Find pins P & L on the PCB and make sure they are connected. If the edge connector has been replaced then it is entirely possible someone didn't do it.
bonehead
50 (100%)
1,729CR
So what you are saying is tie p+L together or just make sure p is connected to ground?
Sorry for the stupid questions but don't want to knacker another cab that I almost fully working.
Cheers,
Steve
4,058CR
Thats OK - it's not a stupid question!
Actually, tie L to GND. But since P is GND, you do that by tying P & L together. Clear as mud
A picture speaks a thousand words. From the wiring diagram of the cabaret:
On the full upright wiring diagram that loop is simply missing entirely.
4,058CR
And just so you can tell which pin is which, since some of the letters are skipped on an edge connector:
Code:
P20: 44-pin edge connector (main/large board)
	        component side        solder side
	               +5V RTN  A  1  +5V RTN
	               +5V REG  B  2  +5V REG
	                        C  3  +22VDC
	                        D  4  -22VDC
	                COIN L  E  5
	                COIN C  F  6  SLAM
	                COIN R  H  7  TEST
	           COIN CNTR R  J  8  COIN CNTR L
	                        K  9  COIN CNTR C
	                 X INV  L 10
	                        M 11
	                   GND  N 12  GND
	                   GND  P 13
	                        R 14
	                 Z OUT  S 15  Z GND
	                 X OUT  T 16  X GND
	                 Y GND  U 17  Y OUT
	(P18:V)          RESET  V 18
	                        W 19  -5VDC
	                        X 20  +12VDC
	(P18:2)        +5V OUT  Y 21  +SENSE (+5V)
	                   GND  Z 22  -SENSE (GND)
bonehead
50 (100%)
1,729CR
Yes it was missing the link. The edge connectors had been replaced and I guess it was missed.
No big deal just really pleased it is now a worker.
4,058CR
Nice - I really must have another crack at getting mine working. PCB doesn't work and I hate them. I've even got a new repro control panel for it complete with screened artwork but I need to drill the bolts out as they're rusted solid and I'm a bit scared of doing them
