Battlezone Sounds Missing
ataridude74
264CR
My Battlezone (cabaret) is having some sound problems, which have steadily got worse. Some sounds work, some sort of work, some not at all:
Sounds that work - UFO saucer hit, tank engine, new enemy tank alert
Sounds that work but are not quite right - radar blip, game over tune
Sounds that don’t work - explosions, end of game explosions
There may be more missing sounds I have missed. Literally, as they’re not there at the moment.
The gameplay works fine, and the AR2 has been rebuilt, so shouldn’t be a power supply issue.
As far as I know the working sounds are the ones that come from the POKEY, so I don’t think that chip is the problem.
Any help much appreciated.
Monstermug
1,807CR
For explosion sounds check following:
Output pin 1 on amp LM324 @ K5. If there is no output then check inputs on pins 2/3. If there is input then your LM324 is bad. If there is no input to 2/3 then check pins 6 and 15 of LS273 @ M2. If there is output on these pins then it could be your shift registers are faulty at M5 and H4. If there are no outputs at M2 it could be that, that is faulty. It wouldn't hurt taking a look at sound enable pin on pin 16 of M2 while you are probing around too.
Might be something else but it's a good start.
It wouldn't be your AR2 because that would effect all sounds not just a few.
