Beginner questions
mrpitchy
6CR
Hello I am new to the forum and have a few very beginner questions about getting into collecting old PCB's and cabinets.
I would like to have a 1981 Frogger PCB and collect more of mostly pre-JAMMA PCB's in the future. I was wondering if PCB's such as this will work seamlessly on a JAMMA supergun or cabinet with just an adapter? Or would some modding/power conversion be necessary on the Frogger board and adapter?
I was thinking of dipping my toes in with a retroelectronik pro supergun and searching for a JAMMA cabinet later on. But am unsure if this is a good approach!
Any help is much appreciated and I look forward to becoming more involved in the forum!
r-type
633CR
Most games will work fine with just an adapter and a JAMMA power supply. Some older Midway games I believe are AC rather than DC though. There may well be other peculiarities with other boards. Mine are all fine with a JAMMA PSU, but the oldest I have is Track & Field or Kung Fu Master.
Hope this helps.
Welcome to the forum.
Andy
ataridude74
265CR
You will be fine with a supergun for just about everything post-1980. Before that a lot of PCBs as mentioned required AC inputs at a whole variety of voltages coming straights off specific transformers.
There are ways to mod most of them to accept standard JAMMA DC voltages, Pacman and Galaxian are good examples where most owners do the DC mod, many tutorials on-line.
69er
1,852CR
the last thing I would like to do is scare you ……….. but more old dedicated boards are damaged using the wrong adapters than actual casualty damage... and it can be expensive this hobby..
if you can acquire pre jamma boards complete with jamma adapters then you should be ok.. but I have been in the arcade business for 40 years and back then I could probably fill a supermarket bread tray just with adapters as there were so many odd ball ones. ITS VERY UNLIKELY FROGGER IS AVAILABLE AS AN ORINAL KONAMI 18 way Sega Gremlin pcb AND IT SOON CAME OUT IN THE UK AS A GAMEPACK CONVERSION FOR 22 way edge GALAXIAN and these were quite common and still survive.
generally most of the galaxian frogger hunchback mooncresta era were fairly universal 22 way connectors but if you get a board fully check up its connector details ……… the ac 'on board' power supply ones referred to above are usually clear to identify as they often have a couple of quite large diodes and smoothing capacitors at one corner near to the voltage in tabs IF THE DIODES HAVE BEEN SEVERED then its probably ok to take the dc voltage direct?? but you need to know for sure put a picture up on here for comments and assurances if necessary. avoid buying boards of this era with blackened or burned edge tabs / and you may find many have had wires soldered direct to the tabs (which could be ok if done neatly and perhaps colour matched to an adapter but not so desired by collectors generally) this prevents the connectors being swapped to similar pcbs - better to make or acquire a dually plugged adapter which can be taken off - ALWAYS BE SURE YOU HAVE THE CONNECTORS THE CORRECT WAY UP TOO...…….. the missing 'idiot key' (pin7 on jamma) key way is present for this reason to prevent upside down connection.. but the adapters often don't have the restrictor pawl in place which would normally only locate the keyway on the pcb .. on galaxians and bootleg copies of later games this is an issue collectors often find undesirable. as well as authenticity.
***If you connect upside down the voltage in will be on the edge tabs the opposite end ****NOT GOOD
if you have a multimeter it is possible to work out what the edge connectors functions are as long as you can find 5v and ground and the 4 video out tabs...……..12v and speaker out can be a bit more difficult to find on some older pcbs
I could go into depth but its not necessary just now ………. mainly once you have a picture the only other tab which will work is coin in so label it then you can find start and then left right up down then go back to coin in and touch it twice you will then find and verify player 2 start...
BUT ON HERE AND VARIOUS ARCADIA GOOGLE SITES people have done this already and I strongly recommend you look them up if working with older dedicated pcbs and ALWAYS BEAR IN MIND THEY ARE APPROACHING 40 YEARS OLD may have been bodged or repaired or be in poor condition generally
my recommendation with a basic supergun is get a couple of early jamma pcbs and try your set up and maybe work back from there GOOD LUCK & WELCOME to UKVAC there are a lot of people on here who will give some advice and help through the forum and much of it IS HERE ALREADY IF YOU CHECK OUT THE OLDER TOPICS back many months/years
as for cabinets expect to have to spend some decent money for the better stuff and again be careful what you go for … check it out as fully as you are able to. hope that helps obviously the older cabs may have only left right action so 4 way movent pcbs would need a joystick control panel simple things like that... many old game need ony one fire or jump button ?? again cabs have been modified up to 6 buttons and two players etc from original just to take a variety of games (but often wired for jamma unless original)
69er2020-04-19 10:59:39
mrpitchy
6CR
Thank you for all your help. I actually went ahead and bought a Frogger pcb today from Jon on the forum. He was great help and reassured me about all the concerns 69er raised above! Also picked up the Jamma adapter he recommended.
Now just need to track down my supergun, power supply, and neo geo adapter. That should get my initial set up going. Hopefully I can get a vertical monitor but that might be harder with the current situation globally.
I am also going to look into some early Jamma pcbs. But I could not pass on a pcb for my favourite arcade game!
69er
1,852CR
take care as not all 28 way connect are jamma ……… sega , some Capcom and Electrocoin pcbs and possibly others with 28 way edge tabs are wired different to the standard Jamma pcbs ……… if it says Jamma on it in the design print theres a 99%+ chance it is Jamma .. as I said previously its easy to connect a pcb wrongly …….. nice to see you take advice seriously and most people on here will be only too willing to help you out if you are trading with them in future...….
mrpitchy
6CR
Ah sorry for using wrong terminology. What would be the correct term for me to use r-type? Stay with me learning a lot here haha. Should I have said vertical display maybe?
I was going to connect to a Sony Trinitron. Which far as I understand will display Frogger in the wrong orientation. So I’d need either a crt I can physically tilt on its side, one where the display can be rotated through settings, or a crt which will display the ‘correct’ way.
I will post a pictures here before I connect everything up to make sure I’m not doing anything stupid (being stupid is my speciality when left to my own devices).
Daz I am from Telford so close by :) what kind of stuff do you have?
Shinydaz
814CR
Pcbs, cabs, jamma adapters, monitors etc....
There's plenty to learn, just ask loads of questions on here.Shinydaz2020-04-20 10:11:04
mrpitchy
6CR
There's plenty to learn, just ask loads if questions on here.
Do you sell online or locally? I will definitely be interested in monitors for the near future. And some more pcbs once I get my set up going!
r-type
633CR
Ignore me pal, I was in a silly mood earlier. I think you answered your own question and I knew exactly what you were talking about - just the way it was written made me chuckle. Almost like asking for a left handed screwdriver!
You are completely correct, Frogger is a vertically orientated game, so when plugged into your supergun, it will indeed be the wrong orientation.
Now, I don't own a supergun, but when I was at school, the rich kids that did just used to turn their TV on its side. Not sure whether that's a good idea with a TV, but it is exactly what you do in a cabinet. the reason I asked what you were connecting to, was that sometimes when I dust off my Dreamcast, I will still turn the monitor on it's side. But it is an LCD monitor that the stand allows you to do this with. I wondered whether you had a similar setup.
As for what people do with only a Supergun and vertical games, I have no idea. Sure it won't be long before someone suggests a suitable solution for you though.
r-type2020-04-19 21:47:43
