I use this for my Blast City, hasn't missed a beat in the 2 odd years I've owned it:
http://www.maplin.co.uk/p/maplin-230v-to-110v-300w-voltage-converter-vr05f
I ran a PC in mine briefly last year, using an
IPAC 2. The monitor in Blast City's are tri-sync, so there will be a VGA (640x480) input on it, just plug your PC into that, give it some power and you're good to go. There are 2 models of monitor Blast's have, one auto-switches resolution, the other doesn't, the easiest way to tell, is open up the control panel, and look for dipswitches that allow you to switch between 15/24/31KHz. If these aren't present, you have the auto-switching model.
I assume your Blast will have the 001 JAMMA harness fitted, so there will need to be a load on 5v , or the cabinet won't power up. I have a passthrough with a voltage display, so I didn't have that problem, but you might want to consider a JPAC if you don't want to go down that road.
cosine2014-12-24 10:55:58
