Blasteroids high scores.
Rasputin
71CR
So, I'm having a weird problem with my recent Blasteroids pickup.
Even though the option to clear high score table in the settings is set to no it still fails to retain any high scores after power off.
Which I find strange as it retains the settings ok eg difficulty, free play etc.
I'm assuming all the save data is written to the same cmos chip?
Any ideas? Thanks!
philmurr
48 (100%)
2,378CR
Blasteroids uses an EEPROM not an EAROM to save high scores. Just 5V supply so no odd voltages to worry about.
As Paul says though they only guarantee a remarkably low number of write cycles so some of the cells could have failed, maybe, perhaps, a wild guess...
Rasputin
71CR
But wouldn't it fail saving the settings aswell? They save correctly, just not saving high scores.. so bizarre.
Rasputin
71CR
Ok so after going through the manual and schematics it looks like it uses a xicor nmos 2804ap-45.
I'm hoping these are still available, still find it strange that it saves the game settings but not the high scores.
Rasputin
71CR
So this looks like the culprit?
Dont think I've ever come across a nvram or cmos chip that's half failed before..
Rasputin
71CR
More investigating suggests it only saves the top 3 scores?
Can any Blasteroids owners confirm this please before I order a new chip!
pobtastic
477CR
Without looking into it further, the settings may all fit into one byte of space (e.g. just like dip switches flipped on/ off ~ the bits in a byte) whereas the high score table is a LOT more complicated with initials and a score in the millions... It may well be that the addressable space isn't accessible past a certain range due to the chip failing or perhaps an IC issue.
edit: I own one, but it's in storage so not accessible ... but I know that CraigG owns one as well (my old one!) http://www.ukvac.com/forum/member_profile.asp?PF=3331 ~ we are both in Northampton too.
pobtastic2019-08-02 09:49:33
Rasputin
71CR
I'm only a few miles from Northampton..
Thanks for everyone's help. I'm going to try and get my score in the top 3 and see what happens :)Rasputin2019-08-02 10:52:21
