I am trying to repair a gremlin blockade pcb for a friend. It's an old game that look like the well know game 'snake' on a nokia phone. The game uses an 8080 cpu.
After hooking everything up all I get is this screen.
Looks like rows of 2 'symbols'. There is a manual for this game and in this I found the following info.
So I thought this might be an indication of failing ram, and indeed there are 2 ram ic's that don't have activity on their output that corresponds with the info above. So I socketed all ram and unfortunately all ram is ok, I tested them in my chiptester and they were good and also swapping them around on the board makes no difference. I have been all over the board and schematic and this is where I am..
-Ram tested ok
-8080 cpu tested ok
-proms tested ok
-found one 7400 ic bad and replaced it with a 74ls00
-lost a clock signal at one point caused by a failed 7426 and after replacing this with a 74ls26 a started running again.
-there is a 7475 in the generation of the read/write signal that only has activity on output pin 9, also the led connected to it is off which seems wrong.
What also puzzles me is that I socketed u22 and u23 that come of the cpu datalines. And when I put in 74ls08 instead of the 7408 that are in the board, I don't get this pattern but sometimes the outline of the gaming screen. The original 7408 ic's test good though so I have no idea why there is this difference..
Also not sure if some input pins need to be connected for the board to start, so hoping maybe someone else has worked on this board an can maybe help me.
-Ram tested ok
-8080 cpu tested ok
-proms tested ok
