Blue Screen (Laptop)
940CR
I am currently in safe mode on my laptop, its a pretty old one Compaq C310EA, recently the date and time keep resetting back to its original purchase date (2006), so the silver battery that retains this sort of info has probably gone. The power supply keeps cutting on and off too, so possibly I have power supply lead fault too, I have to have that plugged in as the battery no longer retains any charges (maybe a couple of mins tops).
Anyhow, when I boot it up, windows 7 all comes etc, but after about 2mins or so, the screen goes totally blue and I can't do nowt. It seems to work though in safe mode without any blue screen popping up.
Anyone have any ideas?
Ben
940CR
Its just a pure blue screen, no writing. I have to power off the computer and turn it on again, safe mode seems to let me carry on as per normal, but fully booting will go to a blue screen after about 2 mins of normal use.
940CR
It did do some sort of update last night before I went to bed, that may well have done something, my daughter had been watching dancing on Ice on youtube and it was on in the lounge, but screen went black (as in turned off when I touched the cursor). very odd. I might just turn it off and look again 2moro night, let it have a break and cool down a bit.
virtvic
The Cabaret King
21 (96%)
2,012CR
Equites
Chief Sheesher®
35 (100%)
3,329CR
Try System Restore before the Updates were applied.
cosine
14 (100%)
595CR
mathj said:
maybe some sort of spyware?
like the ones that lock your pc and tell you to call the police, some of them can be got around using safe mode
Sounds like this, if it can't download/find images to display, you are left with a blank screen.
Probably worthwhile booting to safe mode with networking, and scan using malwarebytes and combofix.
Zektor
312CR
.try too restore to the earliesst date, if it wont let you download anti malware bytes from cnet, update it and run a full scan.....when you see the screen with all the crap it's picked up press CTRL A to select them all then delete them. If it still won't let you run malware bytes then remove the drive and run malware bytes on another pc with your drive connected through USB. You could also run an anti virus scan on it that way if you have a good up to date anti virus.
It could also be a problem with your user profile so while you're at it create another administrator profile and see how that works. Zektor2014-03-14 07:03:16
RGP
Meeter & Greeter
2,039CR
+many on malwarebytes and combofix.
If you have another pc and usb thumb drive download elsewhere and use that to get them on there.
It could innocently be a regular windows update only part applied and the machine powered off. On an older laptop running 7 probably underspecced on ram and a slower hdd 2 mins would be in driver or desktop application loading territory.
as said, try system restore and go back a few updates.
940CR
Thanks folks for the advise, I'll give some a go tonight, I don't think its the malware police pop up, the screen literally just goes blue. I have malwarebytes and one of the first things I did was update that in safe mode and run a quick scan, which picked up 7 things. I will do a full scan tonight, if no joy I'll try the restore, going to clear one of my external drives to make sure some of the more recent files I have are backed up.
While I am asking when the laptop broke last October (screen broke), it had to have a new HD installed because my old one was so full, (it would not allow anymore space for the new screen drivers), I have since bought all the leads (SATA to USB) to plug in my old drive, but I can't seem to actually access any of the files, I can see the data is all still there on the drive, but it won't let me access it, think it called it RAW DATA. - Any ideas.
Purity
The Oracle
17 (100%)
2,999CR
When a drive is labelled Raw Data it means the OS can't recognise the data, which is usually a sign the the MBR/partition table is screwed.
Did it previously have a Windows OS on it?
Zektor
312CR
I did have a similar problem a few months back with a partly installed windows update .....once I managed to reinstall the update it worked fine. It wouldnt allow me to open IE or system restore .
940CR
It was Windows XP before hand, my brother took it away to replace the screen and put a new larger hard drive in, he installed Windows 7.
david_orton_2000
Green Mario
344CR
Hey there,
Dancing on Ice...that'll be the the issue....sheesh! ;-)
Usually with any suspect hard-disk, especially Windoze, I take it out of the machine, yep even a laptop sometimes, then just use an IDE adaptor (you'll need the mini ide one too) + USB conversion.
-Then you can mount on another PC, checking the disk for errors, and remove any bad spyware, etc.
More of a pain for laptops, however at least it is sorted out.
Most blue screens are hardware, drivers or conflicting software issues (e.g. Java Runtime, etc.).
..just fixed so many over the years...sigh, Linux and Unix are just so much better but the command-line is for heroes and the hardened lot only! ;-)
Also, very handy is the 'Ultimate boot cd' which is helpful for a bunch of stuff (basically a cut-down Linux boot). I recommend this one in your 'toolkit' :)
Cheers,
DaveO.
