board identification/pinouts help please
stevebm1
39 (100%)
1,269CR
hi,can anyone identify,these 2 boards and their pinouts please,the bottom one looks like a galaxian boot to me,but im not sure if it's been power converted,the second one I have no idea what it is.
stevebm12014-01-19 07:23:16
4,058CR
Bottom one does indeed look like a Galaxian bootleg or variant.
Top one, compare the pinouts to Crazy Kong or Phoenix and start there.
Basically the way to do this is to start by comparing the GNDs and the +5v's. They're trivial to work out because you can use a meter on continuity test against the logic chips. Next if there are any 4116 RAMs you get get both the +12v and -5v the same way. If not, audio amps are good for getting the +12v.
Once you've got the voltages you'll have narrowed it down enough to make something up and then probe for video. You shouldn't kill anything by doing that.
[EDIT] Typo on RAM number!
guddler2014-01-19 13:29:01
simonden
20 (100%)
1,042CR
Yep, top one is Phoenix boot, bottom is Galaxian boot. Had (or still have) both of those exact boards.
nb: unless you have wires soldered on the back, the galaxian boot is still set up for AC power.
