Bobble Bobble bootleg wiring?
Judder
1,009CR
Hi everyone
After a bit of advice if possible
I'm finally getting around to trying to wire up my adapter for the bootleg Bubble Bobble that I seem to have picked up along the way, and as far as I can tell it doesn't look like the 44 pin dip-out schema shown at Mike's Arcade with extra power cable here
http://www.mikesarcade.com/cgi-bin/spies.cgi?action=url&type=pinout&page=BubbleBobble_44.txt
If you look at the component side it appears that it doesn't have a connector for the extra 'power' lead that Wiretap specifies, but following the board traces the following pins connect to the same location as those of the 'power' lead would do so
A - Ground
B
C
D
E - Ground
F - +12V
U - -5V
V - +5V
W - +5V
X - +5V
Y
Z
Has anyone got a board similar to this and achieved similar wirings to the above?
Here's some shots to explain what I mean which hopefully help
1. Component side showing traces to where the power 'socket' would be
2. Component side close up
3. Non-Component side close up
It also looks very different from this one which is 56 pin
http://elgensrepairs.blogspot.co.uk/2013/03/taito-bubble-bobble-bootleg-repair-log.html
Many thanks for any advice!
Judder
trm
2,877CR
Hi Judder,
I've got a 44-pin boot somewhere that doesn't have the power headers. If you've beeped out the power lines on the edge connector and they match the data I'd go ahead and wire it. As long as you verify 5, 12 and GND you can't kill anything.
Judder
1,009CR
[Edited to correct +12V to be -5V at U, and +5V on V, W & X - all corrections will be applied here - Judder]
Thanks guys for the replies
So I took the 44 pin original pinout, and added in my power connections which were using empty pins on the original wiring and ended up with the following:
[font="Courier New, Courier, mono"] ________________________________________________[/font]
[font="Courier New, Courier, mono"] |Component Side | |Solder Side |[/font]
[font="Courier New, Courier, mono"] |---------------|-------|-------|--------------|[/font]
[font="Courier New, Courier, mono"] |Ground | 1 | A |Ground |[/font]
[font="Courier New, Courier, mono"] |Video Red | 2 | B |Video Ground |[/font]
[font="Courier New, Courier, mono"] |Video Green | 3 | C |Video Blue |[/font]
[font="Courier New, Courier, mono"] |Video Sync | 4 | D |N/U |[/font]
[font="Courier New, Courier, mono"] |Speaker + | 5 | E |Speaker - |[/font]
[font="Courier New, Courier, mono"] |+12v | 6 | F |<Key> |[/font]
[font="Courier New, Courier, mono"] |N/U | 7 | H |N/U |[/font]
[font="Courier New, Courier, mono"] |Coin Sw | 8 | J |? |[/font]
[font="Courier New, Courier, mono"] |Coin Meter | 9 | K |? |[/font]
[font="Courier New, Courier, mono"] |? | 10 | L |? |[/font]
[font="Courier New, Courier, mono"] |Service Sw | 11 | M |Slam Sw |[/font]
[font="Courier New, Courier, mono"] |1P sw | 12 | N |2P sw |[/font]
[font="Courier New, Courier, mono"] |? | 13 | P |? |[/font]
[font="Courier New, Courier, mono"] |? | 14 | R |? |[/font]
[font="Courier New, Courier, mono"] |1P Right | 15 | S |2P Right |[/font]
[font="Courier New, Courier, mono"] |1P Left | 16 | T |2P Left |[/font]
[font="Courier New, Courier, mono"] |-5v | 17 | U |-5V |[/font]
[font="Courier New, Courier, mono"] |+5v | 18 | V |+5V |[/font]
[font="Courier New, Courier, mono"] |+5v | 19 | W |+5V |[/font]
[font="Courier New, Courier, mono"] |+5v | 20 | X |+5V |[/font]
[font="Courier New, Courier, mono"] |1P Bubble | 21 | Y |2P Bubble |[/font]
[font="Courier New, Courier, mono"] |1P Jump | 22 | Z |2P Jump |[/font]
after wiring up my adapter I am getting +12v and -5v fine, but the +5v is not measuring which I think is to do with the original pin-out diagram having
Speaker + on pin 5
On my board pin 5 is connected to Ground (as per the screen shots above) so perhaps these connections are labelled incorrectly on the original pin-out at is should be
Speaker - on pin 5
instead?
[Judder - this was because I incorrectly had V, W & X connected to ground when they are actually +5V so achieved a short circuit - luckily the PC power supply I was using with the Super Gun has short circuit protection, so just shut itself down and waited for me to figure out where I was being stupid
I'm guessing with my adapter wiring Speaker + straight to ground, we get a short-circuit on the +5v as it simply flows straight to ground
Here's the results so far (beautiful spaghetti!) and if everyone agrees I'll try un-soldering the Speaker + and Speaker - and test again to see if the board powers up this time.
BTW my board is the same / very similar to this one on Jrok's site labelled as Super Bubble Bobble
http://jrok.com/boots/sbb_top.jpg
Judder2013-06-10 12:37:21
Judder
1,009CR
[font="Courier New, Courier, mono"] |1P right | 15 | S |2P right |[/font]
[font="Courier New, Courier, mono"] |1P left | 16 | T |2P left |[/font]
[font="Courier New, Courier, mono"] |-5v | 17 | U |+12V |[/font]
[font="Courier New, Courier, mono"] |+5v | 18 | V |Ground |[/font]
[font="Courier New, Courier, mono"] |+5v | 19 | W |Ground |[/font]
[font="Courier New, Courier, mono"] |+5v | 20 | X |Ground |[/font]
[font="Courier New, Courier, mono"] |Bubble Sw | 21 | Y |Bubble |[/font]
[font="Courier New, Courier, mono"] |Jump | 22 | Z |Jump |[/font]
Spent some more time on this this afternoon, and I had incorrectly connected V, W and X as Ground, when in fact they are connected to the +5V rail
So changing that around as follows I now get:
and I'm now correctly getting +5V at the +5V point (multi-meter reads about 4 but then the home one is a bit basic).
But the output appears to be all scrambled as per the screen shot and video below.
Any suggestions what might be causing that?
I have the Video Ground on the Jamma side just looped back to 2 Ground on the Jamma side which I think should ground it fine (without needing to connect to double up connections on the game side) but it looks like maybe the Sync connections are incorrect....
Anyone got a working harness they can take a couple of shots of for me to compare?
I would buy one rather than build one but nobody seems to sell them :)
Regards
Judder
and a fascinating video of the same :)
http://www.alexjudd.com/video/VID-20130519-00000.MP4
VectorGlow
34 (100%)
900CR
Are you sure that 17U onwards is correct? Closest I can find matches yours except for the following:
|GND | 17 | U |GND |
|GND | 18 | V |GND |
|+5V | 19 | W |+5V |
|+5V | 20 | X |+5V |
As for a JAMMA adapter - there are people here and on the JAMMAPLUS forum who will make them, just ask in the Wanted areas. :)
Judder
1,009CR
  |GND |  17   |   U   |GND |
  |GND |  18   |   V   |GND |
  |+5V |  19   |   W   |+5V |
  |+5V |  20   |   X   |+5V |
Hi VectorGlow
Thanks for the reply :)
It _seems_ to be correct as from the following two shots 18, 19 and 20 as well as V, W and X are all connected together in a 3 jumper block.
Also 17 and U seem to connect to each other (U has a through board to 17) and that doesn't appear to be a ground if you follow it along to the power block :(
Maybe there are even more different versions out there!!
If I don't get any more luck I'll definitely follow your advice and ask on the Jamma forums for some help.
The board was repaired by IronGiant and has his sticker on there so I might nicely ask him for some advice too :) :)
Many thanks again
Judder
Judder
1,009CR
Actually maybe my 17 is wrong as if that connects through the board to U then they should both be the same, which would probably both then be -5V as 6 I think I checked and should be +12V...
Judder
1,009CR
ben76 said:
VectorGlow is IronGiant mate
- Ben
Thanks Ben
And thanks again VectorGlow / IronGiant - I'll double check my wiring tomorrow but the 3 x +5V definitely looks right
Judder
Judder
1,009CR
trm said:
How's this going Judder? Are you up and running yet?
Thanks for checking up and, well, not quite yet but I have made some progress I think (work gets in the way of these things somehow
I checked and U was incorrectly connected to +12V, when actually it does do through the board to the -5V above, so I re-soldered that and are waiting to retest on return to the UK
I'm also hoping that combining the +12V accidentally with the -5V didn't do any damage to the components that are connected to the -5V
I also dropped JROK an email, as he has the same type of BB Bootleg board and he said that his came with a Jamma adapter so was doing to have a dig around to find it and try and check or take photographs of the harness.
I will update later next week on return and hopefully get TDT working
[BTW I've been updating the first pin-out diagram I did with all the updates so will keep that as the master just in case someone is referencing this in the future...]
Judder
1,009CR
Yes!
Had some time today to revisit this and started checking out the voltages on the board to see if a. my wiring was correct and b. that there were no issues etc.
Noticed on inspecting that the main chips were getting about 3.75V sent to them (rather than the +5V obviously they require) so double checked my wiring and found the culprit wasn't actually my wiring, but rather the Jamma extension cable I was using to connect the SuperGun tester to the board itself!!!!
So, removed that to stop it dropping the power, balanced the SuperGun on a copy of Mr. Gates' finest, and voila - Bobble Bobble booting in all it's glory
I'm thinking that on my adapter board I should remove the +5V and +12V wires and put it thicker cable instead - just so as to support less potential drop in voltages (*guessing that's a sound suggestion looking at other adapters I have made by previous board owners)
Here's some pictures for reference (*just to make me happy too) and thanks again for everyone's advice.
I've updated the main pinouts in the early post to be correct, so if anyone else has one of these boards in the future, that's the ones to use.
Offending extension cable
SuperGun + Adapter + Bobble Bobble
Judder
1,009CR
P-Man said:
Thanks Andy - Now you tell me
I searched pretty much everywhere and checked all the usual places (KLOV, Mike's Arcade) and even mailed JRok who has a similar board
BTW looking at your pin-outs I think that V / 18 _might_ be incorrectly labelled in your wiring diagram?
Well at least on my board it would appear to be +5V as I have it labelled as 18, 19 and 20 are all joined together in one big 3 block
Cue handy picture showing 18, 19, 20 and big silver block connecting them
Judder2013-06-10 12:46:49
Judder
1,009CR
Actually maybe they are slightly different boards?
Checking your wiring diagram again you have +12V on 7 part side (pin 7 from the left) and that one on the board I have is I'm pretty sure not connected (*see above)
I have +12V on 6 part side instead which seems right...
Weird - maybe there are lots of different wired bootlegs of these around
