Bomb jack sound issues.
penrhos
747CR
I picked up a cocktail off ebay and lying in the bottom was a bomb jack PCB - it was filthy but remarkably corrosion & repair free. I've made a jamma adapter and surprise, surprise the pcb works.
However the audio is distorted and there's a really loud buzzing, the amp gets hot too. I've double checked the adapter I made and it meters ok and matches the diagram I found on klov.
It looks like it's a bootleg rather than an original but as all the other stuff is working - video, coins, starts, sticks & jump. I think the adapter is right.
Sound is speaker + & - which I've connected to the speaker pins on the jamma edge connector.
Anyone had a similar issue?
andrewsm
485CR
Amp should run at 12V so check thats correct. Also if amp has +/- to speaker and is not grounded on one side then sounds like the amp chip is bad.
andrewsm
485CR
Kl. Might be worth checking first but if neither of the speaker outputs are shorted to ground then I would suggest the amp is fried as you are getting a hot chip plus lots of hum?
grobda
1,061CR
sometimes bootlegs use a single speaker wire and the -ve goes straight to ground. check the data sheet for the amp it has, it could be different to a standard pcb.
(usually an amp datasheet will have example circuits and show if the -ve can be grounded.)
penrhos
747CR
Progress - amp is a m51516l and there's supposed to be a cap across the output pins.
Pulled this out and it was knackered.
100uf @ 25v replaced that and two others near the amp.
47uf @ 16v and 10uf @ 16v and the hum has gone. Still have a problem where it's really loud.
So next stop is checking the value of vr1 and the resistor in series with it.
