Booting problem
davesarcade
1CR
Hi,
I am mainly a collector of fruit machines but my 10 year old
son has a 60 in 1 jamma cab. We recently moved it from the
garage to my dads house. It played fine for a while but now
most of the time it not initialize. Every now and a again it will
fire up fine and play without problem. I am not that technical even
with the fruit machines does anyone please have any idea what the
problem may be or may be able to have a look at it for me.
Thanks in advance
Link below to video of what happens
http://www.youtube.com/watch?v=YGryS7Zh8XA
David
Edited by trm to make clicky and add embed.
trm2013-12-30 02:06:28
5,653CR
You appear to live near P-man. I would recommend messaging him to see if he will do a call out.
Welcome to UKVAC btw
backflipper
774CR
It looks like your not getting any video. I woukd check:
- the VGA cable is securely plugged in at bith ends
- the monitor is set to auto input or force VGA
smarty
Ready Player One
1,303CR
On my 48 in 1 I'm sure there is a green LED which is always flashing on/off constantly does that happen to yours or are they just permanently on from power on?
As mentioned above check the monitor is on the correct input if it has more than one.
Other things you can easily check.
Check the dip switches on the board, Dip 2 decides weather you're using a VGA monitor or a CGA monitor yours should be set to 'ON' as you've got a VGA monitor. Turning Dip 4 'ON' and then powering it on should display a video test pattern on the monitor.
smarty2013-12-29 21:03:59
Ordyne
1,282CR
I've had a 60 in 1 do the exact same thing until it totally croaked, unfortunately they aren't the best made things.
Hopefully its just the psu that needs adjusting..
Jase
294CR
First thing I check when a PCB only boots when it wants is to check the voltages. Chances are you need to tweak up the 5V. Sorted out many a stubborn PCB.
