Bootleg board identification
Shinydaz
814CR
Anyone come across this board before, I'd like to know the pinouts to see if it's working and what it is, cheers.
Judder
1,009CR
Try reading one of the EPROMs and see if you can ROMIDENT it - normally helps identify the genus of boards such as that - it looks weirdly like some Galaxian based hybrid love child!
Also - what is the processor at the bottom middle? Z80? 6809? also helps
HTH
Shinydaz
814CR
Thanks yes it a z80 cpu. Unfortunately my programmer doesn't support 2708's because of the different voltage setups on them.Shinydaz2017-01-18 15:16:46
simonden
20 (100%)
1,042CR
That is for programming, not reading. tell the EPROM programmer it is a 2716, then use HXD to cut the data in half then romident.
andrewsm
485CR
Agree with Vic. Universal? edge connector to left prob has 5V, -5 and +12V to it. Unversal type. Working on a Space Panic at the moment which is universal and same connectorandrewsm2017-01-18 18:40:31
Shinydaz
814CR
Well I've read them as 2716, split the file into 2 x 1kb with HXD and romident can't identify them.
I dare not guess the pinouts incase I damage something.
Battlezone
410CR
Figuring out the pin outs won't be too hard with a multi-meter
(it's almost possible to "read" them from the photos). I used
to figure boards out like this from first principles quite a lot and
it can be fun.
In this case it's hard to see without the board in my hand exactly
what A21/22 B21/22 are.
The trick is to power up the board in stages and build
an adapter as you go. +5V/GND first, then probably -5V
is it's needed, hunt for inputs/outputs next (ins will be at
+5V and connected to pull-up resistors, RGBS outputs will
be moving around if the board works), and finally
+12V and speakers when everything else is working.
There used to be an FAQ on how to do this (written by
my old buddy Rick - google for unidentified arcade board).
No guessing on the supplies, but some other pins need guesses
once you've confirmed they are an input for example,
or that they are an RGB.
A1 & A2 GND?
A3 & A4 +5V?
A5-A10 inputs?
A11-A14 NC (Not connected)
A15 Key
A16 NC
A17 -5V?
A18 NC
A19 RGBS?
A20 RGBS?
A21 +12V? GND? Speaker?
A22 +12V? GND? Speaker?
B1 & B2 GND?
B3 & B4 +5V?
B5-B10 inputs?
B11-B14 NC
B15 Key
B16 NC
B17 -5V?
B18 NC
B19 RGBS?
B20 RGBS?
B21 +12V? GND? Speaker?
B22 +12V? GND? Speaker?
Battlezone2017-01-19 16:45:45
RSwanson
205CR
No, it's for reading as well.
If you tell the programmer it's a 2716, then you're likely to destroy the chip.
simonden
20 (100%)
1,042CR
Really? I haven't destroyed a 2708 (as far as I am aware) doing it this way. The only pin out of range on the datasheet is VPP which according to the datasheet is only supplied on programming.
RSwanson
205CR
The VPP on a 2708 is usually the same as a 2716.
2704,2708, 2716, TMS2716 all = 25-26v (ignoring 2716A/Bs).
The reason that some programmers can do 2716s onwards and not 2704/2708/TMS2716 is not just due to the extra voltages, but also because they use GEN1 programming, where the VPP is pulsed to program and not TTL pulsing like later chips.
However, 2704, 2708 and TMS2716 all need 3 voltages to read and write (-5v, 12v and 5v), whilst a normal 2716 just needs 5v.
Eproms and RAMs that use those 3 voltages all specify that the -5v must be applied before all other voltages, and when powered down it should be the last voltage present. If you power those types with just 5v, they will die fairly quickly.
As far as I'm aware, at the time of the 2708s, they all had Texas' design of 3 voltages.
