Bootleg Juno First Transistor
Purity
The Oracle
17 (100%)
2,999CR
Does anyone have bootleg Juno first?
My board had a transistor on the top board in this location but all the others I've seen pictures of (two) on the net don't have anything?!?
Any thoughts would be appreciated. I removed a TIP110 because it was a bodge job and the legs don't even fit in the holes so clearly it is not right!
Purity
The Oracle
17 (100%)
2,999CR
Anyone?
I can see that the original uses a 2SD361. Maybe I should try one of these or an equivalent 2SC1398?
The label on the bootleg does have D361 next to it, so maybe this is not a bad shout?
Purity2020-03-19 14:43:58
Purity
The Oracle
17 (100%)
2,999CR
No one has a bootleg Juno First they could take a look at please?
I'm also missing some caps on the bottom board
If I was to guess what the cap was it looks like a 220uf 16v on an original board. But is the bootleg the same?
Not sure on the smaller cap
RaveN
1,325CR
Am I right in thinking they just do coin counters?
It's just acting like a switch, so the transistor small parameters aren't important. Any NPN BJT transister rated for well over 12v @ 1.5A will do it, so save your money and get something recent.
I can't tell the case style, is it TO220 (looks a bit smaller than that)? If so, something like a TIP31A will do it.
Purity
The Oracle
17 (100%)
2,999CR
Your right it does look like a coin counter transistor, so i can probably just ignore it.
Looking at the original schematics that cap on the bottom board is a 220uf 16v, and the marking where the tantalum is missing says 330 so im assuming that's a 330nf tantalum as a guess
