Bootleg Victory Road???
BulletMag
5CR
I brought a job lot of old faulty boards about a year ago and finally got around to looking through them,
Many are unmarked but can be identified by reading the ROMS.
Then I came across this triple board (my first) the ROMS say it’s ‘Victory Road’ so I looked for PCB pics for comparison ...
It appears there is only the top board pic available and mine is almost identical apart from the SNK logo on board one.
The only ID I can see on the boards are
‘II-30/1’ on the top board
‘4-71’ on the middle board
‘4-72’ on the bottom board
Unfortunately the board powers on but only shows blocks on the left hand side of the screen.
The available manual doesn’t show how the boards should be orientated, so as I found it boards one and two were component side up and board three solder side up, I’m not sure if this is correct but the short link cable only allows this configuration due to the orientation slots.
From my limited experience of arcade boards the bootlegs I have usually change the board design drastically and usually squeeze it to a single board or a board and small daughter boards, I find it weird the boards I have are carbon copies of the originals.
If anyone can help with the identification of the boards or tell me the right configuration of the stack it would be appreciated
Does a schematic exist for this game at all as that would make my life much easier.
BulletMag
5CR
Here are some pics...
Board 1 (11-30/1)
Board 2 (4-71)
Board 3 (4-72)
Lurch666
21 (100%)
4,519CR
First thing to check is that the board are the correct way round.
I have had board where they have been incorrectly with one board backwards that caused to boards to not work.
With the boards connected check the +5 of a 74LS with the +5 of one on the next board for continuity.
That way at leat you know the orientation is correct.
Looking at your pictures the top board has two connectors and the other two have three so I'm confused as to how they connect.By the looks of it the top board used the two connectors to connect to the second board then the second has a single connector to the third but the third board will have two empty connectors.
As for identifying them have you read the roms and checked them with romident or mame?
BulletMag
5CR
There are two cables each having three connectors, so these are used on all boards,
The single connector joins the lower two boards.
I have read the ROMs and they confirm that they are Victory Road
