Bridge Rectifier help
bones
1,628CR
Hi, I have a blown bridge rectifier, it is a kbpc8-02 which is an 8amp 200v unit. My question is can I use a kbpc8-08 instead ? This is an 8amp 800v unit, does it work like capacitors in that as long as the voltage rating is higher it will work ok or is the voltage rating critical with bridge rectifiers?
bones
1,628CR
I probably should of said that the bridge itself is is just sending 9.9volts to a 5volt voltage regulator and the ac input voltage is no more than 11v
7,224CR
As John said should be fine , Just a ' Smoothing unit ' basically. The caps will be higher rating no no issues there its not like your overloading it.
