Bubble Bobble Sprite Glitches
sl121011
9CR
[uk-vac] Bubble Bobble Sprite Glitches
I've started to get jailbars/glitches/cr*p on the player and enemy sprites but only when they're facing RIGHT for some reason. I've tried piggybacking the sprite ram, but that doesn't solve the problem :-(. Could it be the sprite buffers that are causing the problem, and if so, where are they located? From googling likely numbers, I am guessing that the offending part(s) may be a 74LS244 or 76LS375. Am I close, or waaaaaaaaaaaay out? BTW, it's an original Taito board.
TIA,
Christian.
Outrun
3CR
Re: [uk-vac] Bubble Bobble Sprite Glitches
I got one here that I'm repairing for someone with the same problem, any
advice or info would be welcome!
Cheers,
Kev
Outrun
3CR
Cheers,
Kev
4,058CR
Nearly always, yes.
Logic also, but quite often with logic you see a difference rather than a
cure.
There are obviously going to be exceptions.
On 6/1/06 23:00, "Craig Walker" <craig@giz10p.co.uk> wrote:
> You can't piggy back ram can you?
> Best regards,
> Craig
4,058CR
Nearly always, yes.
cure.
> Best regards,
> Craig
